Another Coilpack Question
His gate spring is already 8psi BELOW what the system will run as a minimum. I don't expect much if any change to the boost curve.
By jacobzking · Posted
Does anyone sell a pipe that's made to go from the Greddy FMIC kit for ECR33 (RB25DET) to the Greddy intake manifold? -
Not that I know from experience, but in theory you'd want your gate spring to be as close to target pressure as possible, so you'd go with the higher gate spring?
Before I commit to it as I already have the wastegate off the car, would you change it to the 9psi spring instead of the 12, or whack it back on now and try your suggestion? Edit: Actually I might just swap the spring and see what the logs say after another few pulls, as we know it's still spiking without the Mac valve in the picture so I need more data without the Mac valve trying to combat the issue.
Sounds good Hmm suppose the main thing is, how much do you care about this car? The filler doesn't make for a very good water barrier lol. If there was a tiny little bit of rust forming now, that in 3 to 5 years time becomes obvious under the paint (starts to bubble up), would it bother you?
