33Sedan Posted August 10, 2008 Share Posted August 10, 2008 Hey guys sorry for being a noob but my spoiler brake light has gone and wanted to take it off, the screws for the brake light are under the spoiler, so i have to take it off. Here is a pic of what I can see, i guess i just gotta take em out but i don't' wanna break anything so wanted to confirm. There is a long rubber thing and a small cap thing (if I'm getting too technical just let me know). Do I just yank the long one out and then use a screw driver to pry the other one off? Thanks guys Link to comment https://www.sau.com.au/forums/topic/231737-need-noob-help/ Share on other sites More sharing options...
33Sedan Posted August 13, 2008 Author Share Posted August 13, 2008 (edited) Nobody knows? I tried pulling the long bit out but didn't wanna pull too hard incase it breaks..... Okay it says I can't upload files now :-( "Upload failed. Please ask the administrator to check the settings and permissions" Edited August 13, 2008 by 33Sedan Link to comment https://www.sau.com.au/forums/topic/231737-need-noob-help/#findComment-4072677 Share on other sites More sharing options...
TiTAN Posted August 13, 2008 Share Posted August 13, 2008 4 scews/bolts and a wire going through a rubber grommet. Undo the the screws and just disconnect the wire (should be a plug somewhere along the line) Link to comment https://www.sau.com.au/forums/topic/231737-need-noob-help/#findComment-4072718 Share on other sites More sharing options...
33Sedan Posted August 13, 2008 Author Share Posted August 13, 2008 Cheers man, there was no extra grommet i could see for the light but i guess ill just go at it on the weekend and rip out the rubbers parts and pry at the plastic things and see what hapens. Link to comment https://www.sau.com.au/forums/topic/231737-need-noob-help/#findComment-4072825 Share on other sites More sharing options...
33Sedan Posted August 17, 2008 Author Share Posted August 17, 2008 (edited) Okay i pulled the plugs out, and there were 2 holes each side, one with a bolt which i could unscrew, and the other had nothing under it. I unscrewed the ones I could see but the spoiler was still very much attached to the boot. When I had a look through the whole where the black plastic case that had the clip for the light in it, I could see this, wasn't sure what it was? dosn't seem that it is physically attached to the spoiler, as when i moved the spoiler it didn't move with. All I can think of is that its some form of a clip thing, although when I pull firmly nothing happens, there are no arms on it to push in or nething. Any help would be much appreciated. Thanks Dan -I took photos but I can't upload still. If anything thinks they can help please let me know and i could email them to you. Edited August 17, 2008 by 33Sedan Link to comment https://www.sau.com.au/forums/topic/231737-need-noob-help/#findComment-4079497 Share on other sites More sharing options...
33Sedan Posted August 20, 2008 Author Share Posted August 20, 2008 Heres picks. You can see that only the top whole has the bolt while there is something underneath the second whole which I can't get to. Link to comment https://www.sau.com.au/forums/topic/231737-need-noob-help/#findComment-4081613 Share on other sites More sharing options...
