Cams Motorsports Clubs
SLEEPR85
 Share
Hey guys been looking at few car clubs around adelaide with the intent of doing a bit of track work and wondering if anyone is a member of any clubs such as sportingcarclubsa.org.au or nissandatsuncarclubsa.com, or on a national scale nissansportscarclub.org. I know that sausa have been trying to organise a cams affiliated club and i don't want to tread on anyone's toes but doesn't seem to be happening anytime soon and i really would like to get some track time experience... seems like all this building up of my car has to go towards something :D Your help would be greatly appreciated.
Edited by SLEEPR85
I'm in the sporting car club.
Never been to anything with them but it allows me to have a CAMS license.
So its $235 to join the club and $95 for a CAMS license? So you don't have to actually be involved in meetings and such but you can join the track days and allows participation in events hosted by them?
Mate i tell ya what, join up with the Austin 7 Club of SA, which costs you SFA, get your CAMS licence and away you go. This club is the club that runs the Modern Regularity out at Mallala, So any info you will need is there, and obviously you can do all of the prac days on Saturdays also, Some weekends you could do a Prac day on the Saturday and Modern Reg on the Sunday!!
This would be ideal if you dont want to go to meetings and not actually be involved with the running of a club, but still get info on Modern Reg at hand. Dont get me wrong you can still do Modern Reg if your not part of this club, anyone can do it, its just you may as well find the cheapest CAMS affiliated club to join.
http://www.austin7clubsa.com.au/
Mitsubishi GSR/EVO Club provide membership for $70 including a nice little starting pack. Very Social and Motor Sport orientated club. They have a few GTR R32 and R34 Vspec members, so YES, non-mitsubishis are welcome. Cheaper option than the SCCSA if you only did a few events during the year.
Edited by Catford
 Share
    • A year of slogging through this bearing issue and finally fixed. What a nightmare. The oil pressure increase did not fix the problem. If you would like to read all the details in case you ever run into a similar issue visit my thread on Yellow Bullet. https://www.yellowbullet.com/threads/continuous-rod-bearing-issues.2689569/?post_id=74193031&nested_view=1&sortby=oldest#post-74193031 In the end the rod bearings themselves were the issue. I had switched from ACL (first engine) to King because that was all we could get at the time and I thought nothing of it. Put the ACL's back in after a year of taking the pan off multiple times to change many things. Issue resolved. Can't believe it was just the bearings themselves all along. It has now been about two years since I drove the car on the street or had it at the track. At some point I had installed all solid and spherical bushings in the rear but had never aligned it since it just went on and off the dyno. Alignment was the first thing to do. (Old photo but same concept) Then I took the transmission out and went through it. This was my first gearset install and I've done about 15 since this one and learned a lot and wanted to apply some of these tweaks to mine. The aftermarket shift forks take very well to some modification and I wanted to make that change. Shifts are now super smooth and no having to find the gear. I also recut the 5th and reverse shift sleeves - always wanted to try this and see how well it works. It works very well! No grinds or having to do a second attempt going into reverse and 5th is perfect. Before During After Going back in In rummaging through my spare trans parts box I found the only parts I've ever broke on a stock trans; the 3-4 shift fork - twice!
    • It also depends on gearbox ratio. Those drag cars running 7s passes aren't doing it on an overdrive gear ratio (probably). 1:1 is "fine", the critical RPM for a 50' single driveshaft in chromemoly is 6900rpm.... ....but when you shift into 5th and use 0:73 or 0:8 it all changes. Do you know their rear diff ratio? etc. That's the stuff that matters with regards to it. Whether it actually matters given your use application is also relevent. You may never get into those scenarios, like most ruined GTR's from Western Sydney don't :p
    • but for how long? would it handle a few laps around SMSP in anger?
    • And over it. Need to stop it coming through the floor.
    • Is it running the standard ECU? some sort of data log might help understand where timing, AFRs etc are at.  If it is standard ECU something like Nissan Datascan would help
