Guys, my car is in the shop for other things, but the mechanic said these were pretty shagged and could do with replacing. He has an adjustable set there which are unbranded, but have Japanese NSK bearings in them.
I've never clapped eyes on these things before and really don't know how important it is to get a good set, branded / non branded, or it is one of those items that doesn't really matter. They look like they are decent quality (looks like a mixture of chrome and anodised bits on there.
Any advice here?
https://www.sau.com.au/forums/topic/231807-upper-control-arms/
Thanks Gary, you're already been recommended to me. I've not done anything yet. Thanks for the link.
If I just want to address the play in the stock arms, rather than introduce camber adjustment, can that be done with replacing bushes etc? Is there a kit to go for?
Edited by LotusGTR
The non adjustable bushes are pretty much the same price as the adjustable ones, plus I have never ever seen an R32GTR that doesn't need camber adjustment. Cost on the Group Buy is $183 plus freight.
Cheers
Gary
Cheers
Gary
$183 for the adjustables? Got pics? Thanks.
Since its an R32 i would never personally bother with adjustable bushes in the front. I have chewed out too many sets and couldnt be stuffed with them as it seems the geometry of the R32 is to blame. R33s etc all seem ok. But R32s well i happily run Noltec upper control arms on the front of my car. Good range of adjustment and have been fine in the front of my car for over 2 years now. I have only done about 15,000kms in those 2 years, but they have seen more use and kms then my last set of bushes that failed.
    • Car has been running great, I've put about 300km's of break in time on it. First thing that stands out with properly sealing rings is no more noticeable crankcase smell coming out of my catch can. This may seem insignificant, but the constant smell while driving around was infuriating. It's also nice to see my oil level remain stable. Two new issues have developed that I only noticed this weekend though. There's a very noticeable driveline vibration past 100kmh. I only noticed it now as I've been babying it under 100kmh in the backroads. This comes as no surprise as I'm running a one-piece shaft, and I paid zero attention to my driveshaft angle when I put everything back in. I also have a fair bit of voltage drop on hot starts. The starter audibly is forcing. No issues on cold start though. I must not have removed all the paint under my main block ground during assembly. I'll try and take care of both those issues this week once the kids are asleep.  I also received all the parts I was missing for my direct port setup. I will hopefully have pictures of that up soon. I'm hoping to get back on the dyno the week of June 30th as I'll be on vacation. I'm confident I should be able to make north of 500rwkw on pump gas and WMI. I'll go back again later this summer with E98, but I want to confirm my ethanol content sensor is working properly first. I've never seen it read anything but 11%. This makes sense for our 10% ethanol content pump gas here, but I would expect the occasional movement between fill ups.
    • 75% complete. Will now need to get a new axle with 5x114.3 hubs and then figure out how to customize some mudguards for it once the wheels are on.
    • Trailer prep is underway... Lined up the wheel to get a rough indication of how it would sit Then removed all the bits (as far as possible) and gave the frame a light sand and quick lick of paint   Then added some carpet
    • okay, so I figured this out, removed needles and reinstalled after swapping the gauge face on my triple gauge for my ER34, all work and look good. I tried to do the same for the main cluster, but the main cluster gauge faces are dished, the replacement gauge face are flat, so due to the dish in the org face ,mounting backing plate (clear) and depth of the needle, the flat gauge face will not work. I notice that R34 gtr gauges are flat, appears to be different clear backing plate that aren't dished. are these available, or what have others done to install flat gauge faces?
    • Cheers mate. Seems some people get lucky others don't. It looks like the motor was detonating (to be expected if it was overboosting I suppose) as the pistons had a lot of detonation damage, and the bearings were stuffed. The bores were very scoured too, not sure if that's from the pistons or bits of ceramic turbo. By the by now. Have been trying to avoid the rabbit hole too much on the rebuild, and there's been a few hurdles along the way, but with any luck I'll have the car back soon™. Might even pop up a thread then.
