as is states a r32 gts4t wrecking in melbourne
whole car is avaliabe
sold items are door trims, left hand side window, brake master cylinder, loom, drivers side switch control for windows and rear side panels and boot interior rest all available in melb
Dont know what parts are worth but p, ,e on what your after and we can take it from there or state a price in the post.......
Complete engine and gearbox
drive shafts front
tailshaft
read complete setup
front and rear brakes
clutch cylinder
computer ecu
dash x 2
steering rack
complete front end
front cut??
boot lid
front guards
bonnet
front and rear seats
roof linning
left and right doors complete
front bar
condensor
abs motor in engine bay thingy
and anything else you can think of complete car wrecking
rob 0402090079
https://www.sau.com.au/forums/topic/231820-fs-eoi-r32-gts4t-wrecking-whole-car/
series 1 or 2?
or what year model if you dont know?
and do you have the centre console? ( it goes around aircon controls, cd player, ash tray and follows around the shifter)
sxc33 it is a rb20det single turbo
rad32 it is a standard r32 front bar in perfect condition pm me an offer and we sort it out will send no probs
gts-t sedan yeh i got the surrond i think gimme an offer in pm
7k r32 please have got that pm me an offer dude
PM sent :)
pm's replied to
gts-t sedan i have a condensor and a alternator if u still need em?????
didnt get the pm back
can you send again?
nah all good for them got them a while ago jus tbeen sick and havnt changed sig
thanks though
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
