as is states a r32 gts4t wrecking in melbourne
whole car is avaliabe
sold items are door trims, left hand side window, brake master cylinder, loom, drivers side switch control for windows and rear side panels and boot interior rest all available in melb
Dont know what parts are worth but p, ,e on what your after and we can take it from there or state a price in the post.......
Complete engine and gearbox
drive shafts front
tailshaft
read complete setup
front and rear brakes
clutch cylinder
computer ecu
dash x 2
steering rack
complete front end
front cut??
boot lid
front guards
bonnet
front and rear seats
roof linning
left and right doors complete
front bar
condensor
abs motor in engine bay thingy
and anything else you can think of complete car wrecking
rob 0402090079
https://www.sau.com.au/forums/topic/231820-fs-eoi-r32-gts4t-wrecking-whole-car/
series 1 or 2?
or what year model if you dont know?
and do you have the centre console? ( it goes around aircon controls, cd player, ash tray and follows around the shifter)
sxc33 it is a rb20det single turbo
rad32 it is a standard r32 front bar in perfect condition pm me an offer and we sort it out will send no probs
gts-t sedan yeh i got the surrond i think gimme an offer in pm
7k r32 please have got that pm me an offer dude
PM sent :)
pm's replied to
gts-t sedan i have a condensor and a alternator if u still need em?????
didnt get the pm back
can you send again?
nah all good for them got them a while ago jus tbeen sick and havnt changed sig
thanks though
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
