  • 4 weeks later...
  • Replies 84
Posted Images
  • 7 months later...
  • 4 weeks later...
Deceive is one of the best 31's I've ever seen! There's a few other really nice examples here too.Good work boys!
Here's some pics of my R31. Sold it about 100 years ago now.
It begins!
And dennnnnnnnnn......
And then some real rims were added to the recipe
Ugly Mug! hahaha
This was where it started for me... way back in 2001 :thumbsup:
First HR31 i had. Still to this the day I've not seen a cleaner, factory standard HR31 like it.
It was imported in 1996-1998 or there abouts, rare as hens teeth as it was factory original (except for the wheels).
Only thing i changed was a chip/tune, 10psi & a very tame exhaust... was truely a brilliant daily.
looks tuff
i really like it with the r32 wheels
Ye they were quite good actually. 100% mint conditon as well for a long time (till a gutter early one morning took a bit of an edge off)
The 34R wheels look great as well. In fact, that whole car looks fkn mint!
Ye R34 wheels look awesome, but the offset just doesn't work.
These are the current wheels... only 17s but good rubber (minus front lip etc)
I have a very good friend on the hunt for a nice set of Works 18's with the right offset for some awesome dish... so sometime in the future i'll be a man again and have 18s :D
This was where it started for me... way back in 2001 >_<
a pic of that car asof today
:cool:
:blink:
:D:):banana: I thought someone sold the Racing Hart's off? Fken amazing they are still on there... very sexy shit!
Body does look like it needs a bit of the ole cut n polish though :P
Also looks like it's sitting a bit higher in the rear or that just me? :ermm:
I have a very good friend on the hunt for a nice set of Works 18's with the right offset for some awesome dish... so sometime in the future i'll be a man again and have 18s :thumbsup:
nah you wana get some ssr sp1's in black...... yummy ;)
:happy::) :) I thought someone sold the Racing Hart's off? Fken amazing they are still on there... very sexy shit!
Also looks like it's sitting a bit higher in the rear or that just me? ;)
im the only one to own it after you (or the guy you sold/traded it to), and the racing harts had been swapped with different wheels but now they are on to stay.
probly just the driveway that makes it look like that, rear is slightly higher i guess,
still only 101,000kms on it,
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
