This week i should have new tyres and money to spend on something else next week.
I've decided to spend some $ into cosmetic appearance of my SII R33 and that is the body work.
Ive been constantly deciding between
Do Luck Front Bar
Jun Front Bar
Top Secret Front Bar
Jun Side Skirts
Top Secret Side Skirts
400R Side Skirts.
anyway rear bar isn't important atm as i have pods to smooth out the look until i figure out that part later.
but anyway I've scrolled the internet and found these two pictures of same front bar and just want to someone to confirm its a Trial Front bar.
I really love this front bar as it doesn't have the N1 rectangular vents as most front bars seem to have.
and looks simple yet nice!
If anyone also on here that sells this front bar with any of the above mentioned side skirts could you PM pricing please
I live on gold coast also.
here are pic of front bar.
https://www.sau.com.au/forums/topic/231908-what-front-bar-is-this/
yeah get the trust front bar looks tough and simple
I wouldn't get the jun front bar, but that's just me
the top-secret is like a union of the 400r and gtr styles
do-luck is hot, specially the GTR version
What ever you do make sure if you mix your kits they match
personally i dont think trust front and do luck will work as the do luck sides stick out at the bottom quite far and go with the do luck front shape
My Advice use these options and take what you like best
Trust front or top secret front, jun sides and jun rear
Do luck front, do luck sides and jun pods or trial rear
Jun full kit, the front is not as good as the aboves but the whole package gives it a real fat look
I have do luck front and do luck sides and jun rear, i can just get away with the pods i think
You cab get do luck from dmd the image and othe parts from psi parts. And remember if you get a whole kit in one you save lots of money
    • Interesting, I've heard complete opposite on my end. Bit of a lottery I guess.
    • Getting Dangerously close to being ready to go back in the car. Rockers in with clearance castings now (and a quick check with the USA for the torque settings for the larger custom bolts) Covers and ported FAST Manifold sitting on there. Not fully tightened down as there's some clearancing required for the water pump with the earlier LS1 water pump styles. Example of the clearancing needing to be done: The body has to be ground a little but I'm struggling finding an actual piece of it. The later variant of water pump resolves the issue as the manifold was designed around it. It only came on the VZ LS1 in Australia, it got a different pulley for Gen4 motors. (it also costs $450... vs... $0).
    • https://files.fm/f/5atwkuvcjd
    • Doing some height adjustment on front suspension on a v35 and noticed this. The passenger side looks correct. So wondering what's happened to the drivers side?
    • Oh...I have the electric mirrors as well iirc ...they're in the same state as just about every other R31 door mirrors, with the 3 plastic screw towers broken/cracked in the plastic molding. All the interior is 'dry', so the mirror switches etc likely all work fine. Some pics below of the trimmer pieces ~ looks to me like previous owner, painted chrome finished trims with black paint ...ergo, the chrome underneath is likely a-ok... ...starts to look yukky posting stuff like this, how much did it cost in fuel on your last sortie up this way?...me just thinking aloud, borrow someone else's 4cyl to cut costs, come do your own pick'n'pull like before to save me some bother...hehe.. but whatever, I'll just earmark bits I know you want, because the way this is all panning out, I'll be able to retire the R31 from daily duty at long last, replacing it with a Subaru wagon I'm lining up in the wings...ergo, my attitude towards the donor pinny shell is starting to wane a bit, and I'm more than happy to help you out there... Like you say though, no rush...and I'll guarantee we won't be moving too far from this locale at any rate 😎
