CRD Dyno day - DATE CHANGED - Now Oct 12th 2003
  • Replies 240
Grim: From what Jim mentioned to us he wont rush the cars on and off, so you should be able to have a quick play and adjust your settings - obviously cant confirm this until the day though.
Brett: I'll put your name down
Originally posted by benm
I think Brett should be made to run his car last on the day.
That's a good idea. We should be coming up with some sort of running order to keep the interest all the way to the end.
So Brett should run his stock GTS right up front :stupid:
T.
ok guys we are going to look at keeping it at 35 cars max so things dont get overcrowded. Limiting the cars will also mean that Jim will have time to answer a few questions for you before the next car rolls onto the dyno.
That said - first in first served. The list of people who have said they plan to attend appears in the first post.
hmmm.. i might wind the boost up and adjust my timing before hand then.
count me in.
Christian
    • Hi. I need a new clutch for my gearbox. It is a factory smallbox behind RB20DE NEO. What options do i have? If iam not mistaken the gearbox should be the same as in R32 GTST and Nissan S14/S15? I found some Xtreme Clutch Stage 1 for S14/S14 (i dont know if you know the brand) (UK) OR...is the clutch same as in the bigbox from RB25DET?   Thank you!
    • Listening to an artist called "the flashbulb". Not bad. Makes some fairly well researched youtube vids in various things.
    • Is actually easier than you might think. Assuming you have a spot, youfab up the branch, then just hang a longer than you can fit length of pipe down from there, and chop bits off piece by piece and decde which length was the quietest/nicest, then just put that length up in the place where it will fit. Clever folk can actually make like a trombone slide type arrangement so you can just play it like an instrument to find the best length.
    • Buy her some ear plugs.   Or, wear earplugs so you also can't hear Jackie whining...
    • Necroing this thread in 2025 to say thanks! The Manual for the m60 still has the wrong instructions and says to only press button 2 with ignition on. You are a champ, thank you.
