CRD Dyno day - DATE CHANGED - Now Oct 12th 2003
  • Replies 240
Originally posted by Merli
Is this the EVO 4 that was at the Performance Forums Dyno Day that got 250ish kw @ all four?
No - we know that fella.
V Nice Car. Thats for Sale at a nice price if anyone is intrested! $42k Serious buyers. Thats a Baragain!
He was in Fast Fours last month I think?
But anyway, I'm stock boost at the moment. SO just wanted a power run before my biig list of mods starts... :D
Thanks
Count me in...
Michael
also
I had a friend that dynoed his Pulsar GTiR at C&V 179kw at all 4.
Then on a Mainline Dyno 181kw, then at CRD 178kw .
I htink those are the figures. WIll check.
it goes to show "all these dynos that produce higher figures than others" is just egos making exuses for a crap readout.
But there are lots of variables too. An operator can influence a figure.
:D
Originally posted by franks
christian, are you turning up the boost just because you want to get a high reading on the day?
nah, its tuned for 1.1 bar and its currently only running .8 bar (and running like shit) - so i'll wind it up to what its tuned for.
Apple dont even sell the g4 anymore, but the g5's are still not in stock yet so they can get away with clearing the g4 at a higher price.
You wait, by christmas you would be able to get a g4 (if you can find one) for a huge discount..
Hrm... 2nd car or g5...
Anyway... back on topic :D
    • We just disconnected the vacuum line if I remember correctly, booster is still there. Is there a rebuild solution for the booster or a different adapter that will work for GTR chassis?
    • Yeah 4wd (boosted) has a recess in the firewall for the booster, and 2wd is flat - the example in the link shows the flat surface. When you deleted the booster, did you just attach the factory slave cylinder directly to the recess in the firewall with no adaption?
    • Yes, but no. You need to keep the mating surfaces bare (ie the flat faces where the caliper and upright pads touch the dogbone) and also the internal threads will remain bare (unless there are no internal threads - do they use nuts on all the bolts?). So you can slow down obvious external corrosion, but not all of it. Anodising would be required to provide decent protection to the alloy, but I'm not actually sure if you should anodise something that is all about the strength. Anodising does reduce strength significantly. Like, up to 50% on some alloys for high thickness coating.
    • Thanks   does painting on aluminium work or stop them from corroding?
    • 'Sgot nothing to do with them being Japanese. The climate in the north of Japan has similarities to the UK - the cars are made in the knowledge that they have snow and salt, and they rot there. Cars made in the US rot like buggery in the US. British cars have always rotted regardless of the weather. They will rot indoors in a climate controlled bubble! The brackets are not unsafe yet, but they will get that way. They may well corrode where the bolt threads are in contact and the bolts could just jump out without warning.
