Sorry I didnt know which section this fitted into. Moderators feel free to move it. Ive just changed my rb20 to a topmount setup with a gt3076r. Problem being that the power steering reservoir is too big now with the turbo there. So I thought id rip out the Hicas at the same time and change it all over to r33 gear as its much smaller...I have an r33 reservoir.
Question is: Can I use an R33 Power steering pump on a Rb20? I know the belt has to be changed but does anyone know if they line up or fit the bracket?
I thought other people with top mount setups may have run into this problem on Rb20s
Thanks in advance,
Stu
Thanks in advance,
Stu
I moved the standard reservoir down beside the radiator and just changed the hoses. Thats the easy bit, as ive had heaps of issues with the power steering pump/bracket and offset of the pulley in relation to the harmonic balancer. I ended up having to get the bracket machined in a mill to elongate the mounting holes so i could slide the whole assembly back and forth to get the right offset. If i were you, i wouldnt change the ps pump, because as far as i know, theyre all different. Just move the reservoir (you can see mine in the bottom right of the pic). I ran into these problems because im using RB20 ps stuff with the RB26 engine.
Shaun.
EDIT: I think the changes to the forums arent allowing me to upload pics. You can see where my PS reservoir is in my avatar above.
Edited by Shaun
Shaun.
Thanks for you reply.
The problem with that is I have removed all the hicas gear while i had the car apart. And have had mixed response when it comes to gutting the back of the r32 pump and blocking the hicas outlet.
The tally for will a 33 pump fit on an rb20 sits at yes: 1 no: 1
Can anyone confirm?
Yeah, i removed all the vanes in the rear of my pump and it works ok. The other thing you can do is just use the rear part of the pump to circulate the fluid around to the front of the car so that the fluid will cool down. Because if you remove all the hicas gear, you remove the factory piece of pipe that is used to cool the oil. Depends what your using the car for i suppose.
i'm using a r33 p/s pump and bracket on my 32 still with a rb20. It was the best way to eliminate all the hicas lines running from the rear of the car and around the front. It works perfectly. The p/s belt is silghtly narrower than the rb20 one but no problems with that.
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
