Hey guys, got into our V35 this arvo to be greeted with the icons in the posted picture below flashing on the dash. Now from thne manual it looks to have something to do with the airbag system. Obviously the airbags aren't deployed so anyone have any clue as to what it might be or how to diagnose the problem? Would Nissan be able to help (doubtful I know)
Cheers
look at the seat harnesses first. that looks like a 35 so there will be at least 8 airbags in it. nissan can reset that light for a fee. the consult 2 unit will read the car.
Yeah it's a 35 Chris... I'll make sure to look at the seat harness tomorrow, what exactly should I look for? Loose connections? If not I may have to call up Nissan and see how we go from there :domokun:
I can remember reading somewhere that in most cars, airbags need to be checked as part of servicing, and as said once checked the light can be reset. Is this correct Chris?
I think it's like in some cars when it's time for a service the k's blink when you start up, and will keep doing so until you reset it.
check under your seat there will be a wiring harness and clip, dare say it has come undone
I am 6'7 and I have seat all the way back on its rails,
had some one sit behind my wife whilst she drove and they scrunched the floor mat up under the drivers chair, I moved the chair back next time I drove and the light came on. 35 pesos for Nissan to reset.
I know the service manager so I didn't get charged for it.
Hope this helps
Mike
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
