  • Replies 69
Posted Images
Some more parts i've found:
- Short Shifter (includes rubber boot cover, circlip and plastic bush) the thread is on the inside for the gearknob not the outside = $50 + P
- Endless Master Brake Cylinder Stopper (attaches to 2 bolts on strut tower) = $20 + P
- Turbo heat shields chromed (pair) = $80 + P
HKS 2530's are now $2300 + P
Bendix Ultimate front brake pads are now $50 + P
Std Plenum = $150 + P
Added pictures for:
Short Shifter
Endless brake stopper
Heat Shields
Apexi Super Induction Kit
AVC-R
Cat Cover
View them here
Hey Mate,
Ive got standard 33 Gtr cams if your interested $150
with the standard cam gears
Chears
Garth
hey mate u wouldnt have the standard gtr cams would u?
does the plenum include the throttles and intermediate plate? (i.e everything between the plenum and head)
if not what do you have intake side wise...
Tomei Poncams = Sold
HKS Manifolds = Sold
HKS Dumps = Sold
Std Head = Sold
Sard 700cc Injectors = Sold
Std Fuel Rail = Sold
Sump/Diff = Sold
Endless Brake Stopper = Sold
Nismo Fuel Regulator = Sold
Turns out I got the AFM's wrong, I have a pair of 80mm AFM's with 22680-30P00 A36-000 N62 in an orange sticker (which appear to be Z32's from what i've read).
First person to PM gets them for $460 delivered.
HKS Dumps = Sold
Std Head = Sold
Sump/Diff = Sold
Greddy Clear Timing Cover = Sold
HKS Dumps = Sold
Std Head = Sold
Sump/Diff = Sold
Apexi PowerFC = Sold
Tomei Adustable Cam Pulleys = Sold
Short Shifter = Sold
Available still:
HKS 2530 Twin Low Mount Turbo's with braided lines - $2400
Full Exhaust (front+dump+cat-back) - $750
PWR 90mm FMIC - $400
Apexi AVC-R - $380
Apexi Super Suction Kit - $280
Z32 80mm AFM's - $450
Nismo Low Temp Thermostat - $45
RB26 Cam Covers Set (5 pieces) = $175
RB26 Block 87mm Bored, Honed, Line Bored, Cleaned, Painted = $450
Bendix Ultimate Front Brake Pads = $50
RB30 Block = $50
Ill take the set of 5 rb26 engine covers for $175 - what color are they currently?
Might take FMIC aswel, is it direct fit? Ill get back to you on that one, but the covers are a definate. Can come over in the next few nights and pickup and bring cash
HKS Dumps = Sold
Std Head = Sold
Sump/Diff = Sold
RB26 Plenum + Throttles = Sold
RB26 Cam Covers Set = Sold
Available still:
HKS 2530 Twin Low Mount Turbo's with braided lines - $2300
Full Exhaust (front+dump+cat-back) - $700
PWR 90mm FMIC - $300
Apexi AVC-R - $370
Apexi Super Suction Kit - $270
RB30 Block = $50
Edited by benm
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
