Suspension:
TEIN FLEX COILOVERS
S14 Lower control arm
Other arms - factory
Polyurethane bushings all around
Alloy rear subframe locking collars
GodSpeed Ebay s13 swaybars FRONT : 30.05 mm REAR: 28.29mm
Nismo 1 way lsd
Alignment:
Front: Camber: -2.5/Toe:-1/Caster:5-6degrees
Rear: Camber:-1/Toe:~-1
Hope we can start some good thread here !
Cheers!
P.S.
Thinking about changing swaybars to whiteline adjustables.
Hey,
well yer i dwift....
Front:
ISC coilovers 8kg front
adjustable castor rods
standard LCA's
standard tie rods
aftermarket tie rod ends (on the way)
front strut bar
boxed castor rod brackets
solid bar in between castor rod brackets (equivalent to nismo powerbrace)
whiteline blade adjustable swaybar 27mm
supernow steering rack spacer (passenger side) - to be fitted
small steering rack spacer (drivers side) - to be fitted
S14 steering rack - with power steering cooler
Urethane steering rack bushes
326 power knuckles (gettine made in japan atm)
Rear
ISC coilovers 6kg
whiteline blade adjustable swaybar 22mm
adjustable toe arm
adjustable traction rod
adjustable camber arms
adjustable tension rod (goes between toe arms)
drift pinapples (setup for grip)
alloy cradle bushes
rear link alloy locking washers (x10 each side)
diff spaced from body (at front only)
adjustable rear strut bar
adjustable rear pillar brace
KAAZ 2way LSD
Alignement
Front
+8 deg castor
+2mm toe out
-3 deg camber
Rear
0 camber
0 toe
+3mm traction rods
that is all off the top of my head...
My setup, very similar alignment specs to huddys
FRONT
tein he coilovers swift 9kg springs
cusco 32mm swaybar
castor rod brace
s14 LCAs 5stud
uras tie rod spacers
-3 degrees camber
4mm total toe out
8 degrees castor
REAR
tein he coilovers swift 7kg springs
GAB 27mm swaybar
cusco camber arms
adjustable toe rods
alloy cradle bushes
cusco 2 way diff
0 camber
0 toe
yo heres the specs 4 my cefiro hehe
front:-
isc coilovers 10k
castor rods
tein tie rod kit, rack spacer
gtr whiteline blade adjustable swaybars
-3 camber
0 toe
7 deg castor
dampening 12clicks from soft
rear:-
isc coilovers 8k
traction rods
camber links
toe arms
solid cradles
-1 camber
.5mm toe in
0 traction
dampening 4 clicks from soft
Edited by carter
honestly i think it depends on your swaybars and spring rates... and your style... and ride height...some people like it a bit softer, so you can 'throw' the front in a bit more, and the rear harder to accommodate this.
I've previously had my fronts on about half and rear's full soft, with 10kg front and 8kg rear.
after swapping to 8kg front and 6kg rear springs, i've found that the damper is a bit too soft.
I've now stiffened the front damper to about 70% on the front and about. And also because i've lowered the rear a little more i dont have the clearance for the arches to clear my tyres... so i've made them full hard at the rear temporarily - until the rear guard work commences...
it's sort of trial and error - and find what suits the car, the setup, and yourself
Yeah. I understand. I run 6kg in the front now and 4 in the rear. I guess I need to experiment more. But I really don't like it all bouncy and stuff. I get it when I stiffen the dampers up. Sometimes its a bit scary lol.
your a good man huddy, not may would give away their trade secrets like that. my buddy club coil overs have just arrived, cant wait to install them and go for a skid, every one raves about coil overs, but it goes good with cut springs at the rear and lowered s15 front springs with s 14 front control arms.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
    • If it's reading full rich prior to a misfire that gives one directional hint, if it's already reading lean, etc. If it's reading pretty cleanly stoichiometric then suddenly drops out from a misfire that suggests it's not air mass estimation that's the problem. Could be ignition, could be something more subtle. Could be the CAS has decided to start dropping out at random or the drive pin is worn leading to excessive lash and trigger errors. LTFT can tell you the same but it's slower to react and if this is a recent issue it might not have stabilized. STFT stuck in one direction vs fluctuating back and forth can be used instead but I like to read O2 voltages anyways and interpret directly. If the O2 voltages make no sense in general or are super slow to react it could also be a failing O2 sensor. There's no real error correction for failing O2 sensors in these cars.
