Item: Trust Extension Front Pipe
Age: Less than 1000kms, no hard work at all
Condition: A1 - buyer will be able to see the gate split hasn't even gone 'off' due to the heat as stainless normally does, backing up the low kms/no heavy work.
Price: $800
To Fit: RB26/GTR
Contact: PM me
Comments: Had to pull them off due to ride height, relating to HR31/RB26 conversion etc. Motor sits lower than it would in a GTR which caused me problems so ive regretfully had to take them off :worship:
Pics of what they look like if you dont know. Nengun wants $830 without even considering delivery & extras so these are cheap considering they are the same thing and in virtually the same condition
http://www.nengun.com/trust-greddy/extention-front-pipe
For interstate - ill meet you in the middle for postage costs (ie, ill pay half)
I can probably get it done a bit cheaper through some friends anyhow.
  • 4 weeks later...
Up for sale again.
Ive got a whole swag of pics on my home PC (should you really need them).
With Trust going bust - you might not be able to buy these again!!! :P
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
