Hey guys,
I recently made one of the luckiest phone calls of my life and happened upon the opportunity to trial a new tuning program that can manipulate the factory ECU is most Nissans, including all skylines. The guys at BPS at Cleveland in Brissy were able to change the factory air/fuel ratios, as well as factory boost levels with the standard boost solenoid. My car is an R34 with the tiptronic semi-auto and I have been looking for something like this for a while now and I'm totally stoked with the results.
My car is pretty close to standard, the only mods are:
- K & N Pod filter
- Blitz LM FMIC
- BOV
So as you can see I don't really have any substantial power mod upgrades... not even exhaust yet.
On the first few runs the car dynoed between 155 - 165kw at the treads. After some adjustments, and an extra pound or two of boost and it ran 183.5KW ATW!! With room for more potential, AFM was maxed out due to a boost leak in my cooler piping. Dyno sheet won't attach, but ill work on getting it on. I think the results speak for themselves, pretty awesome option for anyone not wanting to fork out the expense for a full after market ECU.
If anyone wants any further info hit up the guys at BPS and they'll be happy to help you out.
Cheers,
Jizm
Edited by jizza
  • Replies 43
Good on ya mate. You got some decent results.
Only thing I find weird is that you proceeded to tune the car with a boost leak instead of fixing it?
Now your going to have to get another tune once you fix? If it was so simple as a cooler pipe why didn't the guys at BPS fix it before tuning (or when they found it)?
It will be good to see the Dyno sheets once you can attach them.
I was the test dummy for the program so I actually got it for free... but i think your looking at around the $1000 mark, if ur interested I can give you the phone number and BPS can hook you up with a quote. And yes, that does include timing.
Reason it got run with the leak was because it wasn't detected right away. I was keen to get the car back, and we didn't have time to pull the whole front bar off to adjust the hose clamp. I'm fixing up the leak and taking it back down early next week. Might see if I can get my exhaust fitted before then as well to take advantage of the free tune. ;)
Still working on the dyno sheet.. won't upload as an attachment
Lol, sounds like I need far more technical info, I'll phone up tomorrow and get the full details. I don't think its just a remap because from my understanding (which is clearly limited) they install some kind of emulation software into your ECU... Don't quote me on this but I'll find out for sure tomorrow and clarify any questions. I'm quite sure I haven't been taken for a ride because I was of the opinion you can't change factory boost levels and remove speed limiter and boost cut. But like I say, I'll find out full details and end speculation. Watch this space for more details.
Hey this tune sounds good, Ive currently got a 3inch turboback exhaust system with high flow cat, podfilter & a turbotech boost controller boosted to 10psi. How much Kw's can i get out of this if i tune like what you did? Thanks would appreciate it.
Geraus Huynh
Geraus Huynh
If you are looking for a remap then speak to someone such as Dr Drift as he is in Melbourne.
You would get anywhere around the 180-190rwkw mark with those mods and a remap.
Nistune now has a realtime daughterboard for ER34 and we are gathering an extensive collection of various ROM images to support the variety of different ECU part numbers in our next ROM pack release
(We have noticed earlier types dont have the traction control facilities and there is extra stuff for tiptronic automatics in the later ECU ROM revisions)
We have had several workshops install them in Australia and some individuals running them overseas... We are still field testing S14A/S15 and OBD-II USDM ECUs at the moment with the same board. Once that is done we will start advertising the boards on the site. But ER34s run without any problems
For a sneak peek we have the Type 4 hardware installation manual at www.nistune.com
Basically they make the ECU tunable like an aftermarket ECU like the powerfc
I went down and saw James at BPS today to get some more info for the critics.
This is how it goes, similar to what darkhalf mentioned about the Nistune program (nice hi-jack), the tuner can manipulate the factory ECU in real-time, much like an autronic or Power FC. This is achieved by adding new hardware to the factory ECU (daughter board). This acts as an external storage device which contains maps for the ECU, which is different from a flash tune, or simple remap and is better because it doesn't simply "trick" the ECU into running different settings. From here the tuner can remove the speed cut, adjust boost, timing and fuel. The good lads from BPS will soon be providing a more in depth explanation after everyone has finished having their rant.
The results are quite impressive, in fact with my new exhaust the car dynoed at 198.9kw atw, which I'm stoked with. For some reason it won't let me upload my dyno sheets, anyone got any suggestions?
I'm really happy with the result and I'm sure plenty of others will be to. Keep on eye on this post for some more specifics. If you like what you see James from BPS Cleveland is the man to speak to.
Ta,
Jizm
    • Yes, it is indeed that time of year again - the time has come once again for us to sit and discuss the state of our club, and any/all future possibilities! And yes, it is the perfect opportunity to sit and have a bite to eat and/or a drink with all SAU NSW members! Every wondered whether there is more to SAU NSW than just our beloved cruises? Well this is ALSO the best opportunity to quell your curiosity! We discuss everything SAU NSW from current financial position, performance of the club over the past year, the good things we did, the bad things we did, as well as the things we could do better or different! Not to mention, we talk plenty of car talk too.. After all, we're all passionate car enthusiasts! So without any ado, please save the date, and come down and get involved!   When: Sunday 4th May 2025 Where: Toongabbie Sports & Bowling Club - 12 Station Road, Toongabbie Map: https://tinyurl.com/saunsw-agm Time: Meeting will commence at 1.00pm. As usual, lunch from 12.00pm!   Agenda Items: - President's Report - Treasurer's Report - 2025 Committee Elections - State of SAUNSW & moving forward - Future Events & 2024 Calendar - Further Motions & Agenda Items - Open discussion   To our members who are also on the forum, if you would like to discuss any particular item, or have any ideas for the future of the club, please note it in this thread for discussion at the AGM within the NSW Members section of the forum. If you don't have access to the Members section of the forum, then get in touch with us! A note to our members: We remind you that as per constitution, nominations for committee positions close 21 days before our AGM (Saturday 12th April 2025). ALSO, by 12th April, any motions must be put forward, for discussion as agenda items at our AGM. Please head over to the Member's Section of the SAU Forum to post your nominations and any items you wish to be discussed! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • We're bringing Pizzas back!! Pizza Runs, to be specific... We had a practice Pizza Run a while ago, and everyone has been screaming for a proper one... So you've asked, and now we're delivering! Since your tastebuds are tingling, feast your eyes on the event details: Date: Saturday 19th April 2025 Meet Location: Parking Lot - 1 Parkview Dr, Sydney Olympic Park Meet Time: Meet at 5.30pm for a 6.00pm departure Destination: Talotta's Pizzeria, 1-3 Bridges St, Kurnell Map: https://tinyurl.com/saunsw-talottas We'll meet at the carpark on the corner of Parkview Drive and Australia Avenue in Sydney Olympic Park. When we leave the parking lot, we'll head down Australia Ave, and turn right onto Homebush Bay Drive at the large roundabout near DFO. As soon as we turn onto Homebush Bay Drive, we will be turning left onto the M4 to drive through the new M4/M8 tunnel! Everyone loves a bit of RB action through a tunnel.... We'll exit the tunnel at the Gardener's Road exit, and turn onto Princes Highway, where we'll follow it onto Rocky Point Road and then onto Taren Point Road. Once we reach Miranda, we'll turn left onto Captain Cook Dr, where we'll continue on straight until we reach Talotta's Pizzeria for some pizza goodness!!! There is a small carpark at the destination. Limited spaces are available, but there will be plenty of street parking in front of Talotta's There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • The time has come once again, for another SAUNSW Sunday Session! You all know the drill by now, fam... This is the perfect event to catch up with the SAUNSW crew, hang out for a coffee and a bite to eat, and get in some photos and friendly banter! So without any ado, here are the details: Date: Sunday 6th April 2025 Meet Location: Penrith Krispy Kreme (at Penrith Panthers - Panthers Place, Mulgoa Rd, Penrith) Meet Time: 8:00am Map: https://tinyurl.com/saunsw-penrithkk This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAUNSW event and will be run under a Motorsports Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Welcome to the new year, gang! We've ticked over into 2024, so as usual, we're starting the new year with a chill social out at Aqua Golf! So without any ado, here are the details: Date: Saturday 22nd March Location: Aqua Golf - Penrith Panthers Time: 4:00pm Map: http://tinyurl.com/saunsw-aquagolf All you need to do is bring yourselves down to Penrith Panthers to come and say "HI", hang out, and maybe hit a few golf balls at the drive range. Who knows where the night may take us... What we do know is that there are plenty of food options available at the Penrith Panthers complex. For those of us keen to hit a few golf balls, prices start from $7.00 a bucket. Aqua Golf is open til late, so we have plenty of time to have a few hits and laughs with each other! This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks all! Looking forward to seeing you all there!
    • Kicking off our first Sunday Session for 2025, we'll be heading to the delectable Self Raised Snack Shoppe!! Get your tastebuds ready for a mouth-watering toastie and coffee! As always, this is the best place to meet up with the SAUNSW fam for a coffee, bite to eat, and a chat! So what are you waiting for? Block out the calendar, set your alarm in the morning, and come down to hang out with the SAUNSW fam! Date: Sunday 9th March Meet Location: Self Raised Snack Shoppe - Shop 4, 8/20 Sarsfield Cct, Bexley North NSW 2207 (carpark entry via Slade Road) Meet Time: Meet at 8:00am Map: https://tinyurl.com/saunsw-selfraised This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAUNSW event and will be run under a Motorsports Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
