  • Replies 43
Hi. I hope to clear up what it is we do and how much it is.
We modify the stock ECU with a board made with the help of a Korean friend Kuk, from Kuks Autos in S Korea. The m\board allows us to store the "maps" on seperate re-flashable memory, not like UV style chips. Also imbedded is an additional socket allowing the use of a real time emulator. Allowing the skilled tuner, with the correct knowhow and software, to real time custom tune the vehicles ECU. The board is contained within the factory ECU case. All standard diag tools still function perfectly as does the factory boost controller. I have been wondering about pricing, and reading all the posts. As my main area has been remapping mainly Euro cars using only the factory DME (Digital Motor Electronics) for many years. I am sure that you guys can give me an honest opinion. I would think that for a basic tune such as the one shown in this thread should cost $750. This includes a complete custom tune to suit that exact vehicle. Not a simple "blow n go" tune, which are never perfect, or take into account the precise tune for that exact vehicle. The whole job takes over 4 hours start to finish and involves some very expensive equipment. Full enclosed 4WD dyno cell with 20kw of extraction system. Realtime data streaming. State of the art hi speed emulation equipment, allowing real time access to all running maps. Solder re-work station, hi speed programmers, laptops, coffee :P Experienced blokes (who dont come cheap nowdays). Remember that this upgrade allows you, or us to tune the car again and again. Using the factory ECU is the best solution for 90% of tuned cars, all the nice starting, dials working correctly, good knock control, closed loop control, the list goes on. This is less than the cost of a re-map on a LS1 etc, around $600-$700 less than a VW TFSI Golf. I am happy to answer any questions.
We modify the stock ECU with a board made with the help of a Korean friend Kuk, from Kuks Autos in S Korea. The m\board allows us to store the "maps" on seperate re-flashable memory, not like UV style chips. Also imbedded is an additional socket allowing the use of a real time emulator. Allowing the skilled tuner, with the correct knowhow and software, to real time custom tune the vehicles ECU. The board is contained within the factory ECU case. All standard diag tools still function perfectly as does the factory boost controller. I have been wondering about pricing, and reading all the posts. As my main area has been remapping mainly Euro cars using only the factory DME (Digital Motor Electronics) for many years. I am sure that you guys can give me an honest opinion. I would think that for a basic tune such as the one shown in this thread should cost $750. This includes a complete custom tune to suit that exact vehicle. Not a simple "blow n go" tune, which are never perfect, or take into account the precise tune for that exact vehicle. The whole job takes over 4 hours start to finish and involves some very expensive equipment. Full enclosed 4WD dyno cell with 20kw of extraction system. Realtime data streaming. State of the art hi speed emulation equipment, allowing real time access to all running maps. Solder re-work station, hi speed programmers, laptops, coffee :( Experienced blokes (who dont come cheap nowdays). Remember that this upgrade allows you, or us to tune the car again and again. Using the factory ECU is the best solution for 90% of tuned cars, all the nice starting, dials working correctly, good knock control, closed loop control, the list goes on. This is less than the cost of a re-map on a LS1 etc, around $600-$700 less than a VW TFSI Golf. I am happy to answer any questions.
Yes a first class tune on a dyno beats a mail order "chip" which may or may not suit your car. People are charging $250 to $1000 plus for a dynotune. But do you have plans to sell just the hardware and software with instructions? I would be interested in making my ECU tuneable but what exactly can be altered after your modification? Timing across the range? A/F ratios across the range? You mentioned the boost control solenoid -( what would determine its settings?) What else?. I would be interested in a modified ECU that could be tuned by me or my local dyno shop (not being in Aus).
Converting the ECU is not a big problem. However the tuning has to be done in HEX. This means whomever you are going to get to tune it will need some special software. It is not like VCM or Open ECU etc, it requires that you know the HEX address of the map areas you wish to change. Have a talk with a good tuning shop near you, maybe we can set them up to become a dealer for the product and help them with the software. We can tune it here and transferr the files to be uploaded at your end and tested. The chips we use require a particular programmer. You can test the tune on the dyno and we can make the changes here, then send you the file and you "flash" it in and test again. This might work. See if you local tuner wants to get involved. J
You are running a business and no doubt have costs and expenses etc.
the problem for me in justifying $1K is that you are doing what others do for the same results for about $350-$500 at most.
If someone came in with a stock R34 gtt and gave you $10K worth of bolt on parts and asked you to also tune the stock ecu, I'd understand the $1K cost.
but given that the car is stock, with stock variables, keeping stock turbo and afm, then it's the same as any other R34 with stock turbo and AFM.
The very first time it is done for the very first R34, it will take time on the dyno. getting it all right.
but the next R34 you get, why would you not start with the last good tune you did, stick it on the dyno and run it up.
check results and adjust if necessary.
why would that cost $1k (or whatever it the actual final cost is).
Like I said, you are a business with staff and coffee etc.
you have higher costs than say Toshi or CEF11E from these forums... who are members who can do remaps/burns/daughter boards etc.
CEF11E modified his own Stockish R32 GTST to the tune of 240rwkw mapping his own ecu over and over till he got it right.
cost him dyno time and his own personal time.
Then another member with an R32 GTST went and bought the same parts, and payed ceff1e $50 for that tuned chip.
made 240rwkw.
Toshi charges $350 for rechipped/mapped R33 ecu's with certain mods.
everyone that has got it has made the similar power (2 recent ones were 198.9rwkw and 199.1rwkw) in 2 different states.
both had same mods.
This particular R34 of the OP has made the same power as every other R34 using stock turbo with what is probably 10 psi with usual breathing mods.
I'm not saying you did a bad job.
I'm just trying to explain the reason why "I" think this is such an expensive "remap/chip" for what is essentially the same as all the others.
Thanks for the back-up there James. I think what one of the most important differences here that justifies the extra cost is that this is a vehicle specific tune that can be changed if for instance you added more mods that would throw out your original tune and utilises quality technology and expertise. And if you compare the difference if say you were to purchase a power fc then have that tuned as well this is a significantly cheaper option which gives similar tuning perameters.
Jizm
The R32 ECU requires no boards fitted to allow tuning, only a socket to allow the memory to be removed and re-fitted. The cost of a "Postal Tune" for daughter board ECU's could be $500 and $700 for a full custom on the dyno. Even when you start with a dialed in tune it still would require at least one hours time to check and tune correctly. As a note we can also do the Nissan Patrol ECU, with a dual map set up on the board :action-smiley-069: We have a 4800 here just getting finished off GT35/82R Turbo fitted with charge cooler. All running off the factory ECU, upgraded injectors and auto. Should be real silly. We also have complete tuning updates for all GTR35 vehicles including speed limiter removal and rev increase.
Fitting centres in Sydney and Adelaide. I am unsure if I am allowed to put the names up as I am not a sponsor. J
James,
Just wondering if what emulator you are using? Both Bikirom, and myself with NRE have been using the MultiRom16L for several years now on R34s with real time tuning using full map tracing, live map editing, 3D map displays etc etc... I would be very interested in speaking to you regarding the particular boards and data storage with you if you are interested? I'm assuming you're still using the factory option on the R34 of the 80pin ribbon cable with the external maps being selected by moving the 0ohm resistors on the main board?
Also, very interested in other vehicle applications you may have available? V35? Z33? etc...
Regards,
Sam
0425 818 755
James,
Regards,
Sam
0425 818 755
V35 no problem, 350Z, Patrol also done.
I will try and give you a call
I use German tuning tools, come from a background of Porsche Tuning both DME and mechanical upgrades. Ex Factory Master Tech for Porsche UK. Built Cup car engines for a while.
The ECU upgrades are similar to as you described. :D
I look forward to finally talking to "DrDrift" J
Things sure have changed. I've still got my old stock ECU with daughterboard lying around somewhere tuned for 480cc injectors and highflow turbo. AFAIK it was the first in Australia - now everyone is complaining about the cost instead of lack of availability. This thread is cloudy with R33 and R32 ECU talk. Getting a PFC tuned costs $500-800 I guess so how is this much different? Can it be used with different injectors and AFM's?
James,
I look forward to your call, always eager to learn, listen, and hopefully share, my phone is always on. Please feel comfortable calling anytime before 1am, sleep is a dreadful waste of time!
Sam.
i went and saw toshi last sunday i am getting a remap done by him. at 13 psi dropping down to 12 with my set of mods will definetely see over 200kw and all up supplied fitted and tuned only costs $450
i was looking at getting same performance and power figures from power fc and tune which would have cost $2000 + stuff that.
he said he can also do this same tune of the factory ECU for up to 400hp. and has tuned aftermarket turbos. once put on the dyno his road tunes were only the slightest bit out in comparison to a dyno tune. so slight there was hardly any difference. bang for buck. toshi's the man.
Drew - Noting from your other posts you have an R33 and I got the impression intent on modifying it further - The only downside is your ecu is not real time tunable... and no one without removing your ecu and making it real time tunable, or using a real time tunable ecu for tuning and then burn the final image back to a single burn cpu chip (which is an expensive no longer produced and relying on old stock product) back into your ecu, can tune it in real time.
Bang for your buck if your not doing any further mods Toshi is your man.
I am remaping R33 ECU real time tune by daughter board.(and nistune softwear)
And this data burn to single chip.
So I am able to remap any tune.
Single burn chip is much cheaper than daughter board.(Also I am saling daughter board if custermer want to daughter board.)
I means how much is custermer want to pay.
Sigle burn chip is cheaper and daughter board is expensive.
If custermer will go to another state and he want to fit daughter board I am able to do it.
If custermer chasing over 370-380hp (about 270kw)I recommend power FC or any after market computer.
Emision control is remap ecu much better than power fc.
I think street car is remap and like a race car is aftermaket computer.
Remap is much better than piggy back computer for skylinens and silvias ECU.(R34 GTT have boost limitter(about 14psi) and can not remove by piggy back computer)
By the sounds we're starting to flesh out some of the more important similarities and differences a tune like this can offer. And its all pretty interesting to know exactly what's available and how many options we have at our disposal. I spose now its just a matter of finalising what kind of cost is involved and what kind of application suits each specific person. ei. using this tune means that your ECU is still tunable for when you add further modifications, which lets face it, nearly always happens lol.
Can someone tell me which ecu-remap allows boost control using the factory boost solenoid? Or do all of them do it, and a decision has been made not to implement that feature?
I'm not sure if Skyline ECUs implement boost control other than just cutting the boost as a safety feature. My old GTI-R ECU used to run the stock boost solenoid full open (not pulse modulated) normally and close it if there was knock or I declerate or something like that. So there's no facility that I'm aware of (Skylines could be different) that allows you to specify x bar of boost.
Edit: I have a feeling (I could be wrong) that bikirom may have added that functionality via additional hardware. Check on their website.
Edited by BoostedBarge
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
