Unfortunately my beloved '84 Skyline hatch has to go as I now have a company car + 2 motorbikes = no garage space. It has full service history from new, books, 2 owners from new & only 140,000 orig kms. It has all TI options such as 4w disc brakes, elec windows, power steering, auto with electric overdrive etc etc. It also has tinted windows, brand new injectors, 5 mths reg, rwc & tyres are 80%. Drives like new & is reliable as clockwork. Nothing to spend other than servicing for many years to come.
$2600 ono. Car is in Melbourne & pics can be viewed at http://suvvers.spaces.live.com as I can't get pics to load on here but weill keep trying.
Ph Cam on 0439.877.522
Edited by Cam1
https://www.sau.com.au/forums/topic/232086-r30-ti-hatch-for-sale-low-kms/
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 馃槢 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
