Hello All,
Haltech Engineering
556GraviT.net Pictures
I was out at Wakefield on a freezing cold day - Abo Bob and Ports were there (NSW Events) also.
Now for the best part, the Haltech team - testing - Brand Spanking R35 GTR!!!
Awesome group of blokes from Haltech allowed me to take some pictures.
Click the links and Enjoy!!!!
Regards,
Grant
Director - 556GraviT.net
Haltech R35 GTR pics all over the place on...
NSW Subforums>Events>Surprise Official SAU Dyno Day 16th August especially Pages 9 & 10.
Photography thanks to 'Sl!m' and 'God_speed' which were sent on to NAGTROC o'seas.
Thanks also to Envy Imports as they launched their new machine to music and the Haltech R35 GTR.
Enjoy!
  • 1 month later...
Last month at the Powerplay Imports day they were doing 1:09:5s - from memory that was a totally stock car, stock tyres etc...
My inital response was just going to be... "Quick!"... lol
Was it dry. That is a decent time...only i would have expected it to be 3 to 4 seconds quicker
hmm I don't know that they were the world's best driver, but I don't think it has another 3-4 seconds on those tyres, probably only 1 or 3. remember its only got about as much power as your average vic track gtr, and 300kg more.
Yeh i suppose the tyres could have been shagged. But looking at how quick they are in all the magazine comparisons...the 997 GT2 does 1:04s at Wakefield. Russ kicked butt at Superlap in his doing i think 1:15s or 1:16s which compared to what the other cars were doing and their respective times at Wakefield...well i would have expected at least 1:06s.
But yes, perhaps tyres were shagged
I don't think thats a decent time at all.
sub 10's is mediocre these days. You need 8's or better to be considered quick
The NA silvia i just bought has a best of 1:09.3 at wakefield (natsoft) on the old surface. It has 120 rwkw....
You're right to expect 6's roy
  • 3 weeks later...
This car was at the Eastern Creek private practise day on Friday 24th.
Certainly was not very quick - or was not as quick as I expected. I actually overtook him underbrakes into turn 2. I think they were just testing as opposed to trying to go flat out as I imagine it would be alot quicker that that.
In the 4th session the cars motor blew! It was sitting on the grass and had dropped oil on the track. They cancelled the session as a result.
Not a cheap track day eh ?
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
