I myself have a Blits Bonnet on my R32 I got from DMD was a nightmare to get fitted lol, DMD said yea would fit not a problem took it home and guess what the latch didnt line up after a day later dmd got it too fit :rofl: good ol GTR bonnet on a GTST
I still have the paperwork in the car that came with the bonnet, I would of thought it would be lighter than the factory bonnet, must tell you its heavy as all hell and no need to act that its heavy when opening it.
Haha thanks guy, yeh its been a nightmare figuring out whats illegal what snot, blah blah in Victoria..it seems if you ride anything greater than a bicylce here you could be in potential toruble.
After readin all the posts i recon i will fit it...If i get pulled over and im smart about how i tlak to the police and just accept my fate, sometimes they do give yoa warning or just tell you to change it over etc. Its a risk but ill deal, im doing a few other things that technically come under the illegal braket too, like the 10 000K xenon bulbs being fitted... etc...they are little things anyhow.
And with the crash thing and bonnet crubling/snapping/going through winshield, i've heard the stories too...if they are true then im just gonna wear a wetsuite and heaps of padding when i drive my car from no on haha. But seriously i drive the speed limit near 99% of the time and whenevr i go above it its cause i didnt realise it was a 50 or a 60 zone etc etc..
Anyhow thanks guys for the advice, wish i lived in queensland...you guys seem to have it alot easier up there than down here...but looks like its getting tough everywhere in due time. Ps. i can lift my a/m hood with one hand (and im an average guy, not overly strong or anything) so :S that was the concern compared to stock hood thats heavy as hell!
Thanks again everyone, i feel bit more comfortable installing it now that i've heard people's experiences. Ill keep you all posted when i fit it.
good work!! stick it to the man lol.. yeah it's not a big thing the police crack down on as it's not disturbing/harming anyone.. however im in qld lol
how many reports have you heard on the news "boy mutilated by his own bonnet" just like final destination.. then those stories can be taken seriously..
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
