Just recently i fitted some DBA gold rotors to my 32. but i think i made ther mistake of using Bendix Ultimate pads... the squeel like a garbage truck!!!
is there anything i can do to stop or even just minimise the squeel... i heard something about copper grease, aparently it helps?
any ideas?
cheers
LOL!
I think you might have bought 'Race' brake pads and the probley have a bit of steel in them, which is why they squeel.
I drove a GTR before with 'Race' pads in and it takes a race track to warm them up and not to squeel.
Do what Blind elk said and see how you go.
they rnt race pads they are definatly bendix ultimate ...
how do i bed the breaks .... ?
well....did you read the instructions or the box you got the pads in? all pads have to be bedded in properly that is a major cause of squealing if not done properly.
since you've already put some klm on them....
pull the pads out
take the current surface off them using a bench grinder or similar
clean the discs and pads with brake cleaner
put them back in
head out to a nice quiet road, do about 3 stops from 120-40 until you can smell them cooking. then drive without using the brakes for a couple of minutes to let them cool
done. your pads and discs are now set to each other's shapes.
if they still squeal after proper bedding in you may need to try:
putting the anti squal shims back in (you kept them right?)
anti squeal compound on the shims
machine the discs to make sure they are nice and flat
copper grease on the backing plate where it touches the caliper's pistons
rebuild the calipers with new piston seals.
road pads including ultimates do not squeal unless there is a problem. even most race pads are fine. for instance the ones from my avatar don't squeal and as you can see they are pretty agressive.
Alternatively you could just go to the track :(
I recently put on a set of Ferodo DS2500s and they were squealing like a bitch. After a day at Wakefield they haven't made a squeak since. Although Duncan's solution sounds a lot safer than mine
Same thing happened when I put my Project Mu's on. I went out to bed them in with a similar process to what Duncan mentioned but they still squeeled a bit.
Went for a long night in the hills, and they were fine :)
i got the same pad. never had a probelm with squealing. if u bed the pads in properly they will last a long time.
try goin for a nice long drive and dont brake hard just ride the brakes + down gear at the same time to stop for the first 200kays and u should be fine
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
