  • Replies 68
ok, so my best bet is to not reset/init but maybe tweak the maps a bit.
since i have a wideband installed i might see if anyone in perth can help adjust the basic tune to enable it to be driven.
or would it be possible to have the tune reloaded from when it ran stock injectors & afm??
thanks for the quick reply Cubes & everyone
Edited by norwest_rumbler
anyone got a real AP RB20DET pfc and datalogit ? Can someone make screen pics of all the configs needed to copy them into the gtr pfc ?
http://www.3rdgearvtec.net/Andys%20Videos/...RB20basemap.dat Hope that helps. I took it off my AP PFC not sure if it works tho cause I used the Apexi tool that was set for RB25 when I did.
If you have the datalogit they have the sample maps already there.
Transferring the details from the AP engineering map is a bad idea. Doesn't work.
I sitll have clean AP engineering maps from from the datalogit when I had mine.
Norwest... I wouldn't worry about starting off with a 'clean' map. Get the wideband on to it and it will be exactly how you want it anyway regardless how it started off.
The RB26 pfc appears to run smoother than my old ap engineering pfc. + it has air inlet temp fuel/ignition correction. I wouldn't have it any other way.
All though likely never experienced witht he rb20det when hitting load point 12 at 1600-2000rpm on the rb20 ap pfc the car would lean out and get stuck on that load point until it pushed past 2000rpm. Never could tune that issue out. I tried multiple AP engineering PFC's (3 in total). Dropped the rb26 pfc in and bam instant increase in low end torque as it wouldn't get stock on load point 10-12 at low rev's.
a perth member has offered to look at this fc with his datalogit for me so looks like it will all be sorted out now.
thanks for everyones input, ive learned quite a bit so far.
cant wait to get it now :(
cheers
When I first attempted this I looked and thought way too hard about it.
K.I.S.S (Keep it simple stupid) :)
Init the PFC
50% AFM correction.
Apply the appropriate Injector trim for the injectors you are running based on the 444 GTR injectors.
- The Datalogit allows you to enter a greater correction than the H/C does.
Select the appropriate AFM from the list be it RB20/25 or VG30
- If you wish to utilize the Q45 you WILL have to tweak one of the airflow curves
Select the appropriate O2 sensor type if you wish to use the O2. <-- Recommended to tune and leave the o2 sensor off
If you don't wish to use the IAT.
- Zero out the Air temp fuel and ignition correction
- Use an appropriate resistor and wire it up to the IAT pin outs to trick the ecu in to thinking you have one OR bridge the IAT pinout to the water temp sensor of which will require a rework of your cold start enrichment table as it loads the temp sensor as a result the ecu see's a lower temp than it really is.
If you do wish to use the IAT and its associated fuel and ignition correction grab a Coolant temp sensor from a VL/R31 or your RB20 and use that and wire it in accordingly. <-- Recommended
Then simply tweak the map accordingly. Definitely not rocket science. :P
andy assuming you are in norwest just take it to mark at hills motorsport in victoria ave. he can get it running properly quickly. has datalogit/dyno etc available to get it running properly.
As for knock sensors.
You will need RB26 knock sensors. I picked up two for $80 from the local wrecker. Nissan want $310 each when new :S
RB26 knock sensors are 'special/rare'. The SR20/VG30 etc knock sensor looks the same is cheap as chips but its a different part number. Unsure if it would work.
You will need two RB30E/RB26 Injector plugs for ~$8, a 4pin plug ~$5 from the local auto store and a 2 meters total of black/red wire wire ~$2.
Use the original plug chop the existing loom just after the origional plug and fit your new plug so you can swap back to the rb20 knock sensors easily if need be. Make your loom attaching the injector plugs bolt the 26 knock sensors up next to where the rb20 knock sensors usually bolt up and Duncans your uncle. Should take a couple of hours to complete.
The 26 knock sensors appear to be be a lot more active than the rb20 sensors (i've tried 2 sets when i had the ap pfc) max knock I'm seeing with the current tune is ~30-35.
hmm so what will happen if i just use my stock knock sensor? is it too sensitive with ths fc or not sensitive enough?
is it really necessary for me to change the sensor? can i just rely on the tuner using his knock detection equip/cans?
thanks
RB20 det sensors are different. So they simply do not work.
Its not necessary to change the sensors providing the tune is good you don't have to worry. I didn't change det sensors for quite some time.
Just keep an eye out for a pair of 26 sensors when they pop up grab.
so rb20's & 26's both have 2 knock sensors? (would make sense to me being a 6cy, but just want to make sure)
are they easy to change? i had a look & seems they might be right up under the intake manifold?
also ive been told sr20det use the same sensor?
cheers
cheers
Pretty much answers it just there. :D
They are up under the inlet manifold.
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
