Hey guy's been expierencing some major problems with my 4WD System lately and was wondering if there's anything i can check befor sending it off to RE Customs on a tow truck.
The car drives fine for 5-10 mins then my 4WD lights comes on and from there my car starts to jerk down low, clears up abit if i put my foot down and when i turn corners or driving very slowly its like i have a minispool and the wheel has trouble turning.. Sometimes feels as if its leaning to one side in the rear.
If i turn the car off for 5-10mins and start it up its fine agian until the 4WD without doubt comes back on. I've also noticed the 4WD light will come on if i put a fair bit of pressure on the brakes.
https://www.sau.com.au/forums/topic/232227-4wd-system-failing/
run the Attessa diagnostic for starters, this is for a S2, not sure if it works for S1s.
http://www.skylinesaustralia.com/forums/4w...=4wd+diagnostic
check your attessa fluid level
make sure all your 4 tyres are exactly the same, brand/size/wear etc
check the 4wd fuse
thats what happened to mine when the cd stacker shagged a attessa wire, resulting in shorting out engine-bay Big awd fuses
1st check
2nd check, fluid and air pressure
3rd check, attessa been serviced lately? Im waiting on an 0-ring seal for mine, only (lightest of light) leak in my entire vehicle.... keep it serviced and in good knick.
expensive to repair / replace
i was at RE customs wedensday night with my s2 .. and they said your's was coming in on a tow truck .. later that night i launch my car into traffic (auto trans) road was wet ... little bit of slip when i hit the white line .. and it felt like the car put its own engine retarder on ? didnt help my situation of trying to slot into traffic and i hit about 20-30kph's and it slow's back down to 15-20kph's then straighten the steering up again and off it goes ... this is my first 4wd car by the way it may be common i dunno .. i was just dumbfounded by that. but i had no lights come on or anything
IMO, that's common, it's the 4WD drive system kicking in..the ATTESA system is like what the GT-R has (guessing here). most of the power is at the rear, once the rear steps out, power will transfer to the front to straighten it up.
This is my "first" 4wd car I owened but i have driven alot of 4WD Nisssan's and pretty much the same. For me it felt like the car was going to fall apart. You'll get use to it and surprise alot people off the line (just love that nobody know's it's a 4WD let alone what it is)
Edited by BigDirtyJase
cheers man thanks for that *puts wallet away* i'll put my helmet on next time incase i headbut the a-pillar next time ... of the line its fine no drama's ... just yeah last one was a violent reaction got a bit worried .. all smiles for me now thank you BDJ
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
