4wd System Failing!
Would it be stupid to twin charge a skyline? Would that be possible/practical to do on an rb engine?more like convert my house into a facility to produce methamphetamines, to pay for all the over night parts from Japan I'll need to maintain them. Saturday night lotto only pays out so much for division 1
I was more referring to Brett's 100% fit comment, where there isn't a perfect seal between the wastegate piston/valve. I do not believe at that point there would be a discernible difference in spool/engine efficiency. Where as the usual 6Boost style of "twin scroll" which doesn't divide the pulses to the wastegate versus something like a Sinco twin scroll, which is split all the way to the wastegate piston/valve, you'll definitely see a difference. -
Ugh shit, sorry to hear that, hopefully its a smooth and easy process to get the old one back in.
Yeah i thought so too...but iam kinda confused what is what and what to get to make it work. I know i need a push clutch(i get that with that kit i post) It has flywheel too and from what i found it should "mate" with RB25DET NEO. But i dont rly know about the bolt count cuz i saw many videos about clutch on RB25DET/NEO and all of them has 6 bolt pattern... Like here for example... And if i google clutch kit for RB25DET NEO like "all of them" has 6 bolt flywheel...
