drumerboyben Posted August 15, 2008 Share Posted August 15, 2008 I've just got an R34 GTt from Japan, it came with a Momo wheel on it but I decided to go back to a standard one with the airbag. Problem is that the damn light wont go off. It has an airbag canister in there and it's all plugged in but the light keeps flashing... anybody got any ideas? Cheers, Ben Link to comment https://www.sau.com.au/forums/topic/232263-airbag-light-wont-go-out/ Share on other sites More sharing options...
Smitizen Posted August 15, 2008 Share Posted August 15, 2008 I've just got an R34 GTt from Japan, it came with a Momo wheel on it but I decided to go back to a standard one with the airbag. Problem is that the damn light wont go off. It has an airbag canister in there and it's all plugged in but the light keeps flashing... anybody got any ideas?Cheers, Ben I have the same problem but casued by swapping my ecu from emu to pfc. Would love someone to jump in and give us some feedback on how to turn the farken thing off! I've resorted to adusting my wheel to a height where it blocks the light whilst i'm driving!!! Link to comment https://www.sau.com.au/forums/topic/232263-airbag-light-wont-go-out/#findComment-4076882 Share on other sites More sharing options...
Cougar Posted August 15, 2008 Share Posted August 15, 2008 Try the search feature I hear that will fix the problem....... http://www.skylinesaustralia.com/forums/Ai...hl=airbag+light Link to comment https://www.sau.com.au/forums/topic/232263-airbag-light-wont-go-out/#findComment-4077462 Share on other sites More sharing options...
116.hks Posted August 15, 2008 Share Posted August 15, 2008 hey mate. if you have change the steering wheel back to an air bag type you will need to erase the clock spring code. because the vehicle has been driving with out an air bag it has logged a hard code. your local auto elec should be able to clear that code if they can't you might need to go to nissan and see if the have the info on their tech to clear it. hope this helps. Link to comment https://www.sau.com.au/forums/topic/232263-airbag-light-wont-go-out/#findComment-4077530 Share on other sites More sharing options...
Smitizen Posted August 17, 2008 Share Posted August 17, 2008 Try the search feature I hear that will fix the problem.......http://www.skylinesaustralia.com/forums/Ai...hl=airbag+light Farken top work!!!!! The door light trick works!!!!! Cheers Cougar!!!! Link to comment https://www.sau.com.au/forums/topic/232263-airbag-light-wont-go-out/#findComment-4080205 Share on other sites More sharing options...
drumerboyben Posted August 28, 2008 Author Share Posted August 28, 2008 Hey Guys, thanks for the replies, I'm really surprised it worked but it did... what a strange way to fix the problem, does anybody know why it works? Thanks again, Ben Link to comment https://www.sau.com.au/forums/topic/232263-airbag-light-wont-go-out/#findComment-4097853 Share on other sites More sharing options...
Jmaac Posted August 28, 2008 Share Posted August 28, 2008 called softcodes. built into ecu so you can do certain functions without consult the workshop manual tells you how to take it out of diagnosis mode using a wire and the consult connector. I cannot remember the sequence for it anymore unfortunately Link to comment https://www.sau.com.au/forums/topic/232263-airbag-light-wont-go-out/#findComment-4098097 Share on other sites More sharing options...
