Continuing , there's 4 TD04 turbines and A TE04 thats a little larger than the largest TD04 (HL) and a little smaller than the entry level TD05 turbine .
People with European cars claim 300 odd hp from TD04HL-19T turbos so not too bad for what they are .
Always remember that Mitsy turbos are generally bush rather than ball bearing so they walk a fine line between boost response and power range .
A .
  • Replies 43
thanks guys for the info have taken all to consideration and in the end i have gone with the hyper gear turbo the tr43 gen 3,
i went with a cheapo one for the time being and when i build my 26/30 i will go all out on the turbo and all the gear.
will prob go 3540 or something simillar
yet again thanks for the help and advice
Hey Trent, when do you think that you will be getting more of the 8cm l2's in?
Just pm me if you would like as ive got a few questions but am interested in buying one...
Thanks mate,
Ryan
I looked at the 6cm when i changed from 10cm to 8cm. The 6cm is bloody small. I think the 6cm is definitely 1.5L territory and for use on twin turbo 6 cylinder setups. I was tempted to try one until i physically held one in my hand. Tiny is the word i think i used.
Im looking at doing the same thing at the moment with mine :cool:
I reckon i will bolt the 10cm up and do a back to back with the 8cm to overlap on the dyno whilst tuning just to see as im not 100% convinced that i will see much more with the 8cm rear!!!
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
