Here are some pics of the damage this is the #6 cylinder piston and it is the worst. All 6 of them were damaged. Also a few close ups of 3 spark plugs, as far as I can tell they show no signs of pre-det from what I can tell. Just carbon/oil marks from being rich and well burning oil due to serious blow by.
As you can see in the pic the damage is ONLY on 50% of the piston all on the intake side. The exhaust side of the piston is as smooth as they day I bought them...
Timing was 16 degrees WOT @ 16-17 psi through the 67mm. 2.7 liter 8.5 to 1 compression. Super super conservative. 93 octane A/f's were 11.0's WOT till 7250rpm were I was letting out. Intake temps around 30-32 C, coolant 88-92 C. I didn't appear to be having EGT issues during this time. It was before when my exhaust adjustable cam gear was super retarded w/o me knowing (finally found the issue) and I was missing 50% of my power when my manifold/turbine housing would be glowing as red as a stop sign after a pull or two.
Question comes down to what does a knowledgeable person on reading pistons feel would make it only melt on the intake side?
https://www.sau.com.au/forums/topic/232311-melted-pistons-only-on-intake-side/
Thats crazy, I would be clutching at straws really to give anything haha. Is there ANYTHING else about the setup that you think you could share? What kind of air filter were you running? Its a bit weird there isn't obvious pitting/strange shape in the piston - ones I have seen from lean run or det are usually a lot less "smooth" than that, its almost like its been machined and I'm sure you'd have mentioned if the spark plugs had melted or anything like that. Its rather odd.
The more I think about it, the more I think its gotta have been detonation.... did you have knock mic on it etc when tuning?
Edited by Lithium
i have had something similiar happen to my rb27 in the past making big power (600hp+). Mine didnt melt any plugs but did some serious damage to 3 forged JUN pistons and the other 3 were starting to go as well, also on the intake sides only, cylinder 1, 3 and 6 from memory. My head looked the worst, have u got any pics of the chambers of those cylinders to see what its like?
how much power u pushing at the time?
send me a pm with pics if u like and i can let u know what was causing mine.
Edited by unique1
"Super super conservative"
Um no.....you have detonated it to death.........
See the pic with the side of the piston eaten away....det does that, and yes generally on the intake side.
16 degs (altho it may sound low) can be way too much sometimes, it all depends on the individual engine/setup.
Some combos only cop single digits, while others love 25+...
thats wat happened to me, except all 6 pistons were just fktttt....... It was the bad fuel and topped it when i took it to echuca ....... My friend has access to echuca Airport after hours and its insane man....... but ye now a rebuilt engine with forgies and i will never treat her with standard unleaded again.... Giving my 33 normal unleaded is like slapping god in the face.... YOU JUST DONT DO IT hahahahahaha
Looks like a big case of too lean.
Why it does it on the intake side is due to cylinder inefficiencies on intake. Swirl in the chamber or intake valve shroud or short side radius air flow etc etc. will cause one part of the piston/chamber to have a problem with detonation first.
I suggest you find a new tuner if they reckon all is well.
Cheers
Marty
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
