I own a skyline gtst and people are always trying to drag race me with 4wd cars. Gtrs, Pulsar gtir ,evo's ,ecpilse etc.
First of all i do know that Gtrs are the top dogs. and I'm planning on buying one in the coming future.
If it wasn't for this unit i would stand a chance.
check the link out and please give use you thoughts on the unit.
http://www.world-motorsports.com/products.php
  • Replies 46
Its not clear to me how exactly this thing works. I like the operating method of the Jaycar boost controller which is triggered by the duty cycle of the injectors and can absolutely eliminate any boost going to the wastegate actuator until you want it to. I am about to install my Jaycar EBC (at about half the price of the above - although that is for the build it yourself kit) - people who have used them say they work as described so sounds ideal to me.
This is not to say that the new device mentioned above is no good - it is just not clear to me that it would be better.
Its a boost controller
Its the same as any other boost controller - it controls boost.
So whats your point?
Its no better than anything else save for the expensive price tag
Yep they will do that.
So let them race themselves on the street and save your fun for the race track where it belongs.
That boost controller has nothing special about it at all.
Eclipse? As in the Mitsi? I thought they were FWD?
Read before you talk the same advice that you gave me then you'll see the benefits
lol so what everyone at performance mag. don't know what there talking about.
(ignorant as i thought.)
see if any GTRs can hit these times
This is a 4WD eclipse and this is one of his bad times
keep on dreaming GTR fans show me something better. (thats real)
I'll give you the world wide web to find a GTR as fast as this, don't even think hks skyline. when you all find one, I'll show you the last video thats not on the net.
so step up
Dude why are you showing clips of 7 second prepped drag cars as an argument why a boost controller (which is the same as any other) gives them an "edge"?
For the record, the fastest GTR @ present i believe is the 7.57 @ 191mph by the Heat Treatments GTR.
Is that not faster than the vids you posted?
Or am i again, missing something magical and elusive?
I honestly think you have NFI what your talking about
let me guess was it build in australia.? lol
the car has ran a 7 sec flat and keep in mind that everything about the car is quarter the size and price.? i guess you can't beat that.
i guess that is why the australian dollar lost its value.lol in the last 10 years keep up the good work guy's thats why the japs rule there more open minded. selfdevlopment, most of you should work on that.
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
    • Yeah very valid point. I am waiting for one of the other tuners to come back from vacation so he can help me a bit when the cat is installed again. In the meantime I am going to finish up my polishing and ceramic coating that I have started myself.    N45 Dr Beasley product is highly recommended for a paint primer / polisher. Using this EXO Gtechniq also for the ceramic but next time might use the light serum before hand also. Looks great.
    • Running rich in conditions where it shouldn't probably won't do great things for catalytic converter lifespan. I would fix that sooner than later.
    • Yes, important point. Watch the Motive videos with Herman thickness testing the bores and deck. You do not want to push the unlucky (thin) block as hard as you can push the average block.
