More Boost?
Damo
 Share
When I bought my car the owner gave me this green T piece which he said will boost the car, all u have to do is put it on one of the lines that lead to the solonoid, but only do it if u have a boost gauge. I have some pics of where it is to go and what it looks like.
Can someone tell me if this is a safe way to get extra rwkw and also how this might work. I cant see how it is a good idea as the solonoid is taken out of the system. Would this lead to problems?
Nah it does boost it up but is very dangerous because different sizes will give you different amount of boost my mate had one before his boost controller on his gemini.
They cost about $1 from pirtec but you must b carefull when installing them as your turbo may overboost and F**K everything
I personnaly would would recommend a turbos*&t bleed valve over that.... and definately don't touch boost without a gauge, preferably a dyno to check your fuel as more boost places demands on your fuel pump. If you loose fuel pressure you will be looking for a new motor :stupid:
When boosting don't go over 1 bar or 15 psi on the stock turbo.
Doc/.
 Share
