i ahd 5% on my car for 2 years, untill one after noon, whilst pulling out onto a street in the rain, a un marked cop car saw em, and gave me a """ to change: notice thing, no fine etc, but 12 days to change :D it was a bitch in the rain at night. some streets inpossible to see, like if a car had no lights on at night, couldnt see it , but i miss it
my brother has his white r33 in same stuff, should i post a pic???
heres pics of my brothers car, at night, and two during the day.
also here is one of mine, its interesting as u can see how dark the window tint it.. yet, if u look through the windsheild u can see how visible things are (( the window is up)) its all good untill u get to night, then it goes jsut as dark as looking in than out lol))
5% yo
it was farken dark and limo spec but i loved it, getting it on with some chick in the middle of the day with just a sunshade in the front window lol
pitty the new owner had to rip the tints off when he took it to SA
if i couldnt see anything i just put the window down...
Ive got like %18 on the audi now and thats enough for me..
  • 4 weeks later...
My R34 with tint, Just below "darkest Legal" whatever that is..its bout 5% under that cause i saw darkest legal and i asked him for slightly darker... Visibility at night is quite fine unless your reversing and theres absolutely no street lights its a bit of a bitch...thats about the only thing you have to wory bout.
My tint has some sort of metalic reflector in it cause it seems to reflect like a pearl tint more than a standard dark tint. :S I havn't noticed this on many other cars other than limo's etc... I hope cops don't get too picky cause i still have to display my P's and you can't see em...
    • 1. Factory knock sensors for now, honestly the RB26 OEM knock sensors seem ok as they're flat response instead of resonant type but they appear to be internally grounded to the block. If I do replace the sensor it would just be to get ones that are not internally grounded so a differential input can be used to reject common mode noise. Definitely plan on fixing this as a part of the tuning process. 2. Never deliberately induced knock, though I guess I could try that experiment if I really wanted to. 3. All of this is basically on a stock engine + ECU, only modification is HKS GTIII-SS turbos and a Nismo plenum. Currently I run it with the wastegate solenoid unplugged so it won't try to raise boost past wastegate pressure.
    • After being peer-pressured into paying $100 for the MW remakes, got BO6 on XBox Game Pass. I think that's worth it.
    • That's a given!  Bit hard to powdercoat it properly without removing them! 😁
    • No detail on compressor or turbine sizes, which doesn't help with housing size selection with that kit. However, from SR20DET mucking about and money torching perspective, a GTX2860R Gen 2 w/ 0.64 (46mm inducer) will do ~260kW on E85 about 1.5bar of boost. All in before 3000pm, which cause a gearbox to shatter. Now imagine the same turbo, on a modern motor with an extra 0.5L of displacement, and heaps of cam timing adjustability (not an on/off affair like the Nissan shit boxes). If this was my car (which I would never own or consider buying, ever!), I would go for a nice twin scroll setup, and a G30-660. Gates plumbed back, no silly shit. Lean on the cam timing, big displacement to create a flat-ish torque curve.
