Hey guys...
I sold the silvia so its time to clear the parts..
S13 drivers seat
good condition
$50
Silvia twin Headlights (RARE)
Perfect condition with globes
$350 FIRM
R32 GTST Rims
Good condition. 2 tyres good and 2 not so good
$250
Set of Coilovers
Zeal Fronts with camber tops
G.E.T Rears
$650 FIRM
Q45 AFM (90mm)
As new condition with plug
$300 FIRM
5 stud conversion
S14 front hubs, calipers, pads and discs
Rear 5 stud S13 hubs
$1000 FIRM
R33 GTST Calipers with almost new pads
$400 FIRM
All items are pick up from Mount Gravatt
Call or PM 0408 605 725
Cheers
Jeremy
PICS
Seat
Headlights
R32 Rims
Coilovers
Q45 AFM
R33 Calipers
  • 3 weeks later...
one last thing before i make up my mind: what do I get with them? all clips and bolts? brake lines? anything? sorry for being a bit of a hassel! Just, i'm a poor uni student with dreams of grandure for his car...
You get all clips, brackets and bolts for the hubs. The metal brake lines are attached. The hubs are complete from stub axel to calipers. they are still all boxed up since I got them. If I still had my Silvia they would be on it already lol... but have an R33 S2 now so no need for them
