Ha ha, yep thats why I paid more. Too get my build finished this decade.
Spool rods did have an issue a few years back with rod bolts stretching, but that has been fixed as they include genuine ARP bolts now.
Eagle and others seem to be cheaper now too.
Edited by GTRsean
  • Replies 373
Posted Images
The way the N1 pump is designed doesn't always fit the way people use them. the drive gear in the pump is made tougher but the process makes it more brittle bouncing the engine off the rev limiter/launch control rev limiting acts like the hammer action on a drill and the gear cracks and falls apart.
Yeah that's exactly what I've seen somewhere else. Was either another SAU thread or on the GTR UK site. I was all sold on the Tomei pump then had someone tell me that the JUN one was better. But Ed from Autotech said that the JUN one wasn't good. So hard when a lot of this is so opinion based.
So at the moment I'm thinking the Tomei oil pump.
Guys that have done this all before me, can you please let me know wht brands you have used for....
Cams
Pistons
Conrods
Injectors
Oil Pump
I have some ideas now and wanna hear what everyone else is using :D
Cheers.
Cams: Stockers for last build, now 272's
Pistons: CP's in 86.5
Conrods: Spool
Injectors: SARD 740cc played with ones
Oil Pump: JUN, now dry sump
nah tis all ok with me im only after getting back to normal engine ability, im going to do gaskets, rings, pistons, rods, bearings, and then machine it etc and put back in. only wanna use stock power levels or boosting to 10/12 psi etc. plan is to sell after i turn 21 and go back to just using my wagon for a while and save for a 34 gtr v spec hehehehehe
Does anyone know of anyone besides Pro Engines for their engine/head work?? Keen to hear of other places and people's experiences! :D
Getting the respray quoted tomorrow and about to start ordering some more parts. Funtime is not too far away!!
Yep, going to get it on a truck and send it over. Easy to do the engine bay since its already out. They'll also be doing my coilpack cover and cam covers etc.
Keep ya posted! I'm also staying white, not changing colour.
Send it up Kat...our head work is top shelf PM Jz R33 as we just did an engine for him that he picked up on Saturday.
Our engines have a proven track record taking out several Autosalon power championships and powering our R32 drag car to win the Australian title in 2004-2005. We have just built our current engine in our race car to push over the 1000hp mark and into the 8 sec bracket.
Im doing a couple of engines for ACT customers actually...you may know some of them.
Edited by DiRTgarage
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
