  • Replies 373
Posted Images
Awesome thanks for the additions! Where abouts is yours getting built? I'm getting excited now!
I was going to look at the Denso injectors, heard a lot of brands use them and rebadge them.
I've seen Greenline but I think they're pretty slow with shipping. I actually have Slide hooking me up with quite a few parts now :)
Nismo full gasket kit eh? I am going to go the Tomei one i think.
HP ratings, also the 044 isnt designed to be run in tank
BUT
There are so many people with 044 in tanks that have had zero issues, including 2 gtr's i know of which are thrashed properly, and mine. There will be a tiny bit of tinkering to get it in there and hooked up but its not hard, hell even i figured out how to do it and believe me im not a mechnic
Go the 044 :)
I've always found greenline to take atleast a week, and have always been spot on when they tell me when the items are dew in.. also never had a problem with nengun either haha..
I'm getting my motor built in Sydney by Pro form. who does alot of my friends work..
As for denso. i'm sure your correct there in saying alot of people rebadge them.. or with injectors really its just re packaging them.
the Nismo gasket kit is a full motor thing (all the oil seals, valve seals, all other engine gaskets there must be over 50 gaskets in the box, unlike the tomei etc which is just headgasket, intake gaskets, exhaust gaskets.
the only problem is you do not get all metal intake and exhaust gaskets. but you do get a metal head gasket. which i already have so not a problem to me.
i've always found its best to use genuine engine gaskets with rebuilds. had, seen and herd of many motors leaking out the main and other seals after motors installed.. and who wants to be pulling out a motor just after its been put back in... tho obviously head gasket is always choice
as for the fuel pump, your best going an intank setup.
  GTRKat said:
Im confused.....
lol sorry, typed that in a rush
Get the 044, mount it in tank, any fittings needed can be sourced from motorsport connections in sydney. Ring them and tell them you're putting an 044 in an r32 and they should know exactly what to sell you
  DiRTgarage said:
SCAT are made in the US....ive already debunked this myth that everything is made in China in another thread.
They all look identical to me, and on scats website, they say they make crank shafts in the us. but only say they finish, balance and pair up sets of rods in the us..
  GTRKat said:
Thanks LTSJayce. But I'm sorted :)
LOL you are more than welcome to come for a ride. I have decided on all the parts it's just a matter of getting them here on time now!
Hi; me again. Maybe I missed your post, but who did you decide on? If you don't want to give away your secrets to the whole world, a PM will be fine!
I think it's in there somewhere :) No secrets. Won't be posting my final figure nor a full parts list so as to avoid unwanted attention but happy to chat to peoples about it elsewhere.
But work wise I've gone with Autotech and Pro Engines.
    • Yeahhhh, the costs have killed me. Spent more than the cost of an engine rebuild and it most mostly servicing and a tune lol.
    • I'm not 100% how the BMW racers do it, but I know from other brands like Merc, moving, and changing the coolers is one of the things. Like getting a transcooler out from infront of the radiator to out near a wheel arch. So some of the stuff you've got crammed in the middle front, spread it out and open up where you can in the bar to get more air in to the sides.
    • Small update for the day... Turns out the intercooler and engine coolant hose kits are anything but complete....I probably should have counted better but it only really covers about half the coolant hoses in the car, it really just covers the visible stuff and pretends everything else doesn't exist (turbo water feed and returns and also heat exchanger lines through the 2 pumps and cooler) .In any case, I'm happier to have half reliable hoses than none, but a bit of a disappointment. Anyway...finger click (and 5 hours).....hoses in place, lots of spring clamps replaced with screw clamps, and engine coolant is on the pressure tester for the night.   Incidentally, upsized header tank is an Inifiniti factory option....not sure I'll ever do prod car racing in this but at least it is legal.
    • Just weld it onto the hot pipe. If you want it right after the turbo, put it right after the turbo. Or rip the comp cover off and drill and tap a hole into it.
    • hahaha glad I can rely on you two to go on a spiral at the drop of a problem! Some quick answers....the ducting is excellent top bottom and sides....everything that gets in goes through the coolers (noting the oil cooler redirects it out again, fair call if it is cooling 120o+) and the heat exchanger for the intercooler also has some scoops to pick up more than it's fair share too. I can't see going down the water spray track....no bueno for formal racing and a big risk for long rally days if you run out (plus I'm not clear if it is allowed there either yet).   Frankly, it must be possible to reliably put 400kw through a standard front end, the BMWs do it so I just need to work it out....I'm starting with reducing blockages in the way and adding some coolant capacity with a bigger header tank, flushing rad and making sure it was filled/bled properly (I didn't do the last coolant change); also taken measurements incase next step is a bigger/higher capacity custom radiator
