All going well i hope :)
My sump was finished today, motor is ready to go on Friday - thats one more white r32 out there on the roads :D
What happened to your 1st RB30 combo? Wasn't it just finished earlier this year?
  • Replies 373
Posted Images
A little update... My head is finished (have pics coming) and apparently looks so good it's a shame that it has to go back in! It will all be assembled and ready to go so the engine will be back to my mechanic on Monday.
Yay everyone cross their fingers for me getting my car back in just over a week!!!! :thumbsup:
Autotech don't do dyno run ins anymore and I'm happy to have the car and do it myself.
His words... "ive been told to use cheap mineral oil and take it up the mountain and load it not reving past 5000 rpm and also not to baby it"
Dunno about cheap oil, I'm not the one putting that in... But this is pretty similat to what I've been told. That I can flog it but only really up to 5k.
Like everything there's 1000 different ways to do things so I don't really care what it says on the internet, I'm doing what my mechanic and engine builder recommend since something gives me the impression they may have been through this a few times.
Good to see things are moving quickly for you! Maybe you'll have it all run in and tuned in time for the Supra Club dyno in (this hasn't been confimed yet, of course) mid January? You can come and show what a GTR is capable of :)
By then I'll already know what she's pulling on the dyno so might go out for a look but wouldn't bother to enter. It'll be quick and fun to drive but I didn't build it to be a dyno queen.
Hehe most of us don't build them to be dyno queens.. but a daily driver that makes anything upward of 400 kW at the wheels is always nice to see at a dyno day. And without being a arsehole, you'd have to bring a bit more than 400 to a Supra Club dyno day :)
Hopefully we can organise a track day with both clubs and test these bad boys out!
As my thread says the whole way through I'm not looking at anywhere near that much power. No point competing with guys that have swapped out their twins for big singles.
I'm much more interested in a track day. In my opinion dynos are only good for tuning a car, they're no indication of what the car can do on a road. I only went to the last day so I had a before figure at all four wheels for my engine rebuild.
Is Ed going to check the tune and afr's etc before you take it, especially since it's now a 2.8? A bit of dyno time also helps to check for leaks after a brand new install too, often happens no matter how careful you are.
Late pm or early am is good so you're not sitting in traffic, and can drive it the way you need to. Bateman's and back is a good varied run.
Re mineral oil for the run in, most is too heavy for RBs (Nissan rec 7.5W) and the special run-in stuff is about 25W. Turbo seals don't like that. Closest I could find was Penrite 10W-30 mineral and that showed high but still OK pressure on my mechanical gauge.
You've probabably already thought of all this, of course definately go with what Ed and Greg say, just my 2c.
Cheers and good luck!
He most certainly is :banana:
Shit time of year for a coast run too with school hols and what not but probably an early morning run is what I am after but see how I go.
I have no idea what oil they're putting in I just know that it's different and needs to be changed after the run in - leaving that all up to the boys to handle.
Cheers for all that!
Man I just want it back!!!!!!!!!!
Oh I know what you said, but you wouldn't be the first to get a taste of more power and start looking for more and more :blink:
While dynos are *meant* to be a tuning tool, they can give you a pretty good indication of the way turbos respond, and how much power & where it makes it that your driveline combination is capable of. Turning that into performance on the street, track or dragstrip is the trickier part.. but a car that makes good power on the dyno *should* still be a fast/quick car.
I do know what you're talking about... and no matter what your dyno sheet says, it means nothing real-world unless you have the track times or E.T.s to back them up. Hence my keenness to get on the track :D
Edited by sdistc
i know it sounds crazy to use cheaper oil, but it is important, my engine has also just been rebuilt. the reason for this is that for the first couple of days the piston rings need to bed them selves in, this is almost imposable to do on good oil especially if its full synthetic. you need to get the piston rings to wear in, once this is done you can go to a half synthetic for the first 1000ks and after that you should be OK to go a good full synthetic.
hope this helps
and all the best with the rebuild
    • You have found the problem. The wire from the switch to the HB is shorted to earth. Now you have to physically find it and replace it. It won't be the switch, although following the steps above (and yes, where you ask, that is the light switch on the RHS of the binnacle) will rule it out for sure. Or not, if perhaps the switch has melted. But there's no route to earth inside the switch, so I can't see how it would.
    • I did read your post, a few times actually.    Done. Followed this step. [Negative probe should be on the cars chassis. Positive on the wire.]   Did this partially.. now that im reading this over, i only unplugged the LED lights. [Start as said above by unplugging everything (unplug the lights, and switches.] When you are talking about the switch, you're talking about the knob thing on the right side in the drivers seat right? If so, i need to take that apart?  [Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch.] At this point are you referring to the connector by the headlights?  [If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.] Did this. I can confirm that the LED lights aren't the issue [Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.]
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
