  • Replies 373
Posted Images
Well started doing it the drive home after I picked it up... Few times when I stopped at lights it'd just cut out so I'd have to restart it. Doesn't do it every time but idles a bit funny too like it's threatening to do it. Did it 4 times yesterday when I drove home :(
Also when I was driving to a friend's place I started losing boost/power and could hear a hissing noise... At the friend's place, I checked under the bonnet to see if I could work out wtf was going on. Found that a clamp was loose on the big air intake pipe on the right hand side (the one with twin turbo written on it) and the rubber hosey part coming off it was slipped down. Fixed that and tightened it and seemed to fix the probs breifly but happened again when driving home.
Checked the same spot and this time it looked fine... Getting it all checked by Autotech tomorrow to be safe and I haven't really driven it much since cause it's pretty embarrassing!!! Looks like I'm stalling all the time :(
I should add that I know it's quite possible that I have more than one problem here. Could be any number of things as to why its cutting out.
Air hissing and already 1 loose hose found likely to be caused by the person playing around in that area on Friday.
hi gtrkat, i have been following you're progress so far and u have all the goods motor wise. and with any build the headaches and dramas arrise when everything is put together and you're driving it for the first time.
from you're last post with the looose hose/pipe/clamp ' air-hissing' noise and it stalling, i'm sure u'd have to change you're spark plugs as they would be fouled by now, so factor that in when you go to talk to the electrician, and get him to re-emburse you for them.
just my 2 cents. good luck with the car, and hope to see it on the road soon, problem free :D
Hey Matey cheers for that. It was only driven a tiny amount before getting fixed. I'll get onto the guys at Autotech and get them to check it but it doesn't feel like they've been affected by this at all - I can tell you he will be paying for them if there's an issue though considering they're brand new!
Not yet but Greg is going to snap some for me before it goes :D
Autotech are also going to take some of it all fully assembled before it gets dropped back in.
I was just reading through and noticed there were no pics of the head so I attached some below. Someone asked what the weight differences of the pistons were, lightest was 366.9, heaviest 368.3, the pins were within .1g. Matching them up with the lightest piston on the heaviest rod small end I had to remove a max of .7 grams from some rods. The crank was balanced as well. The crank balance from Tomei is very good but you can get it a touch better. The kit fitted with no mods to the block or pistons. Overall the 2.8 is a really nice kit.
Kat, I saw the dyno graph from the initial tune the other day, very nice torque curve! Will be nice to see once everything is sorted completely.
Some pics of the head:
Cheers,
Greg.
how is yours going now Steve-O? what kind of response are the GT-RS's giving with the 30?
Mate its on the run in tune (got 400 more k's to go, ill do them quite fast) then swap ECU's and go for some decent boost. Its just the best combo on the big bottom end, wish i did it sooner and didnt waste time with the 2.6 block :D
Basically its got the response of the poxy little stock twins but way, WAY more torque and once the boost is there the power aswel.
Hey Greg cheers for that! I'm so happy with the car, words can't even describe!! Torque curve is great, its just such a different car now! (Should add that more pics are on facebook and my photobucket of the whole process)
Run in tune is done but still not doing anything terribly nasty to her just yet. Few things need to go still, in the not too distant future I'll be getting a metal cat and choosing another exhaust as mine both aren't up to scratch anymore. Will also have a new front mount but not sure when... Kinda letting our finances settle after such a large amount of work and Christmas all at once!
Much nicer to use setup than when you had the GT47 on there then?
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
