  • Replies 373
Posted Images
brakes.... always a good option when you have lots of power lol
LOL yes always helpful! Has anyone experienced the use of the ABS in their Skylines?? First time I had I swear I thought the ass end of the thing was going to fall out!
first time i had to use my ABS i thought the car wasnt going to stop i had to yank the hand break up so i would stop
oh and i get the ABS light on my dash all the time so anoying sorry to steal the thread Kat anyone know how to fix this in an R33
Kat, I have to say congrats and thank you for a great read. I read it from start to finish. Probably won't be all that long until I'm up for a similar experience (I would say minus the stroker kit given price LOL).
Haha thanks! Glad to be of any assistance/amusement :)
Totally worth doing, not that it was ever in doubt but has completely renewed my love for the car!
Sounds great. It must be ballastic with that power on the street.
How do you find the ORC twin plate? I just bought one, yet to be installed.
Now that I'm used to it I love it! From what I hear it isn't as bad as some, there's a little give in it!
Once you get it in, wait and see how many looks you get at the lights and how many people tell you that you've done a clutch bearing or just think something is really wrong in general in terms of the noise it makes :D
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
    • Good question, I don't really know tbh...I'm pretty stock thought, where could I check this?
    • This. I'm confused by the whole discussion. The only reason you would have a car with e85 only if it was track use and you only ever used e85. All other use cases you add a flex fuel sensor, do the flex tune (you only need to do a couple of % and then interpolate the rest) and then you put whatever the hell you feel like including a mix in the tank and it just works. Want a long drive? fill with 98 Want max zoom? fill with e85 Got a half tank of 98 then find e85 somewhere? Throw it in.
