hey ppls
anyone no the exact size of a 33 gtr intercooler ? or anyone have one and want to measure how far apart are the mounting brackets please :) ???
I got an intercooler today but the brackets are 80cm apart.. The place to mount them on the plastic thing on the car is 90cm apart though. just trying to see how its possible..
i would of searched but it doesnt seem to work, just sits there when u click search.
thanks
https://www.sau.com.au/forums/topic/232394-33-gtr-intercooler/
cool thanks for that :huh:
just to confirm, the bit between the red arrow is 80cm ??
tis odd.. my new intercooler is 80cm apart... however the plastic thing on the car it mounts to is 90cm apart ??????????
hows that possible ???
your missing the mounting brakets, theres two brackets for either side of the cooler. One mounts to the chassis, then the other goes between the cooler and bov return pipe. the two brackets are then connected via a rubber mount (like a bottom radiator mount).
Dont mount the cooler to that bov return pipe on its own, as the only thing holding that return pipe in now by the looks of it,are the rubber pipes/hose clamps on either side of it.
Ill take a photo of what the mounts/bracket look like in the morning so u know :huh:
I hope that made sense, iam too tired atm lol
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
