N1 Pumps Vs Nismo Pumps
GTRsean
 Share
Just bringing up another thing on RB oil pumps.
Sydneykid and others have already brought up plenty of info on the various oil pumps and setups available at the moment.
I just want to know who has had any experience with the NISMO oil pumps that are available as well. They are roughly $900ish.
They are not N1 oil pumps, so they must be different, stronger?
Cheers
Jun....hmm, better save up some more!
Here's a pic of a stock r33GTR pump vs an N1 pump I have pulled apart.
Wider and bigger gears, stiffer oil relief spring, more robust and flow friendly housing and a different shape pressure relief valve.
Haven't seen the inside of a Nismo pump.
  • 3 weeks later...
Okay, I'm going to use an N1 housing I have lying around and buy a new billet gearset that is made to suit the housing. It'll cost $550 for the gears.
They are CNC machined billet. The material they use doesn't require hardening.
Only doing this as I already have an N1 pump with gears I ain't gonna use.
if you got bulk keshhh HKS 3.2k
Edited by Blitz:
If you wish to continue advertising your products on this forum, you will need to register as a trader.
Please do not continue to promote parts you are offering until such time as you pay to advertise.
Great, now I don't know what pump it is...
I know the top on in my pic is definitely an R33GTR stock oil pump (it's out of my R33 engine).
What is the bottom one then.....I have another pic of it.
There are no nissan markings on the casting, the insie of pump has a smooth coating on it and oilways are cast for more flow compared to stock.
The gears are wider and larger in diameter than stock gears. 85mm diameter and 12mm thick.
Relief valve is different too. Also has roll pins x2 as locators?
Anyone?
Edited by GTRsean
Edited by Blitz:
3.2K for a pump! I thought that was a reason to not buy HKS! The 4 stage dry sump system on my vw race engine cost only about 1k more than that, and it could easily be adapted to a GTR engine.
I cant imagine why anyone would want bigger than a jun or trust pump and a nice 8lt upgraded baffle sump on 99% of nissan engines. Add some restrictors and isnt that the most proven reliable lubrication system out there?
if it has an alloy plug for the relief valve, and a threaded block off on the side its probably a jun. but definatly aftermarket.
whats the back of the rear cover look like? did it have allen keys as aposed to screws holding it together?
could it be a rd30 diesel onE ???? who knows but its a go-er regardless.
duncan. the rb30 pump has a steel inner gear sleeve thingy. and is a spur gear type not a gearotor type. also smaller.
definatly not a jun pump, jun pumps have a andoised red bolt for the spring and also the back casing will definatly say jun
It has no threaded block off.
Rear cover is flat and screws look the same as stock pump screws (countersunk philips), just one extra.
Couple of things, it was used on a narrow drive crank by the look of the inner gear :P
And the alloy pressure relief bolt had a valve shim to bump up the spring tension on the relief valve (you can see it in on of the pics in the plug lol).
 Share
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
    • those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
    • Freshly built stroked RB25/28. Motor runs great but consumes a lot more oil then It should. This summer with the heat I was consuming roughly a quart per 1800-2000kms. Now with the cold weather coming in, I'm consuming a quart per 1000kms which is no bueno. I had originally chalked this out to break in taking a little longer then it should, but I'm now around 4000km's on this engine. I think it's fair to say something isn't quite right. Here's the kicker, can't find what's causing it. I've also spoken to my engine builder and Precision Turbo and can't figure it out. Here's my train of thought on possible causes and what I've done.  Precision Turbo - I originally started thinking my oil pressure might be a tad too high for my 6466 Gen2. I took the center cartridge out, and while yes there's signs of oil on the turbine heatshield, it's very moderate. There's also very minor in/out play that concerns me. I sent pictures and videos to precision and they said the residue and in/out play is minimal and they doubt this is the issue. For piece of mind, I went ahead and installed a Turbosmart OPR V2 to bring oil pressure down. Made no difference. Precision is willing to take it in on RMA for an inspection and I'll probably take them up on that offer for peace of mind. BTW. Is it just me or does the turbines inducer's look clipped and not even between each other? I just noticed this now while posting and looking at the picture zoomed in. Might just be the picture...  Rings - Hot compression test and leak down test look good. Compression is 160 +-2psi across the board. I leak down at 16% on cyl 1,2,3,5,6 and 18% on cyl4. Keep in mind I have a snap on leak down tester and they read high (I.E, 15% on my wifes 2018 Sentra with 70000kms). Sparkplugs show minimal oil (Only #4 seems to have a tad). At a quart per 1000km's though, I would be expecting them to be wet. Here's the kicker, I run WMI. I'm thinking what if my compression rings are great, but I have an oil control ring issue on cyl4 and my WMI is steam cleaning the pistons and sparkplugs? I can still see the "Spool" logo on top of my CP pistons. The only time I see smoke out of the exhaust is in the high rpm/load range. So far, this is my main culprit. I'll probably turn off my WMI and go out with the car at spring pressure tomorrow and repull the plugs. Other thing that's strange though is that I have never seen any oil in my catch can. Thing is still dry after 4000kms. Cyl1 - Left, Cyl6 - Right. Valve seals - They're new and I would expect oil consumption on idle, first cold start or during decel. None of which is happening.  Crankcase pressure - I have 2x 10an valve cover lines to a vented catch can. Head drain and opened up internal oil drain paths. I also don't run E85. I've never seen any oil in my catch can. Doubtful this is causing any issues.  Rear main seal - I have no visible leaks, but figured maybe it was my rear main seal. After now having added 2-3 quarts, I would expect oil to leak out the bottom drain channel and/or my clutch to be slipping.  Let me know your thoughts. With winter coming and taking the car off the road until spring, I'm fine with pulling the motor apart but I would hate to take it all apart and the turbo was the issue in the end.
