Hi all,
Had my 1997 RSFour on the rollers last week. Just thought Id post up the graph with a list of mods so we could maybe start a cross referance or something to see how eachothers cars are running and with what mods.
As said above mines a 1997 RSFour Mods are as follows:
  • Splitfire Coilpacks
  • HDI Frount Mount
  • Profec B spec II EBC High boost set at about 11psi
  • SAFC2
Was dynoed in RWD (front tailshaft removed)
https://www.sau.com.au/forums/topic/232457-on-the-rollers-last-week/
I had my 98 RS Four S :thumbsup: on the Dyno a week ago for a couple of power runs. It has a GCG Hi flow, CES Racing split dump, high flow cat and a 3in cat back exhaust. According to the guy doing the Dyno it was hitting Boost cut at 14psi.
Good for a starting point I think. At least now I can go from here.. Forgot to mention it was done on an all-wheel drive Dyno.
Edited by SSStagea
hey guys here be mine at all 4s and a empty bank account.
tomei cams and gears
forged pistons and rods
n1 oil pump
flowed and balanced
greddy intake
90mm throttle body
gt35r turbo garret
40mm gate to small and restricting my power going bigger soon
front mount
going full 4 inch zorst old zorst to small
tomei 740 injectors sard reg 044 pump
studded block as old block cracked
arp bolts in every thing
tomei head gasket
many other mods to much to list .once i change the gate and zorst wil pay with timing and more of a tune will go 300awk give or take .advan built and tuned .
sorry my pics wont up load will keep trying
Edited by bernardshorty
I do need to post up my graph, and I saw nick post his today too. will update this thread when i post it elsewhere
mine was done on a 4wd dyno, 155kw
power mods are
power fc
12psi boost
turbo back 3" exhaust
splitfires
walbro fuel pump
standard intake, intercooler, injectors, afms etc etc. oh and manual conversion that probably gives me a couple of kw without the slushbox.
sssstagea you need to get a computer and tune asap. the standard computer responds very poorly to mods - 130awkw is not right for a highflow turbo running 14psi....your setup should be good for 170awkw+
looks like all the stageas have good midrange but poor top end compared to a skyline motor - fits with mark's theory that they have small cams compared to 33 gtst. we are going to do some back to back test with r33 series 2 cams shortly.
Comes back to the same 'rich retards' idea that I was getting with mine, I could feel the car pushing against the 'glass wall' because all the timing had been pulled out by the ECU and as soon as the engine neared the redline it was like a switch was flicked somewhere and all the timing came back for a last minute 'kick' before going back into slug mode again. :huh:
pics wont work since site update(lost my old avatar & gallery) added new pics to my gallery inc. dyno but cant upload.
ces s/s split f/dump ces exhaust.
greddy fmic.
mbc 10 psi.
safc neo.
k&n panel filter.
185.4kw front shaft removed.
  • 3 weeks later...
Hi all,
  • HDI Frount Mount
  • SAFC2
I can't see your graph. Could you post up the KW please?
I had my 98 RS Four S :3some: on the Dyno a week ago for a couple of power runs. It has a GCG Hi flow, CES Racing split dump, high flow cat and a 3in cat back exhaust. According to the guy doing the Dyno it was hitting Boost cut at 14psi.
How are you regulating your boost? I guess you are on a budget like most of us or else you would have a Power FC or suchlike already but I would recommend getting a Jaycar Independent Electtronic Boost Controller or if you are just bypassing the solenoid reduce the size of the restrictor to lower boost. Mr car made 155AWKW (200bhp) with the stock turbo on 10.5 psi and i would expect to do quite a better with a GCG highflow. Have you still got the standard side mounted intercooler? If you car is a series II then maybe you already have the GTT SMIC otherwise that would be a worthwhile cheap and simple upgrade. There are two or three aftermarket options for the SMIC and I was luck enough to find a cheap second hand Trust one. But maybe first upgrade your fuel supply (pump and regulator) if you haven't already.
hi guys im just wondering if you guys who have put up dyno results of your stags are you running autos or manuals?? and are they s1 engines because the power figures seem to be a bit low for a neo . my 99 S2 RS4 stag with just a 2 1/2 inch exhaust turbosmart boost control , BOV and 5 speed manual with 10 psi ran this post-50654-1220741966_thumb.jpg
Yep your neo has a slightly bigger turbo and possibly different cam timing from my Series I auto which made 155AWKW (see above for chart). But when I install my IEBC etc and give it a tune I expect to get quite close to your figure.
power mods are
power fc
12psi boost
splitfires
walbro fuel pump
Perhaps someone with access to FAST could compare the part numbers.
Sorry I can't tell you much about my setup due to only owning the car for about 2 months and not knowing anything about Turbo setups. The guy running the Dyno said that it hit boost cut at 14PSI, not sure if this is what it is running at all times. As far as I know it hasn't had anything done to change boost but looking at everything on this site it must have. I need to find someone that can point out any changes to my setup cause I don't know what looks normal and what doesn't. After reading through this site and getting myself confused on aftermaket engine management I ill also need to go to a workshop or speak to someone who can point me in the right directions. Would really love to find out more about if anything else has been done.
Going to the Gympie skidpan day so will talk to some people there and see what they say.
