R33 Workshop manual.
Simply buy the manual, go take to a print shop to get it potocopyed for around $100 i would guess(Copyright laws go to a small time copier he wont care)
OR even better go to centre Link and use the free photo copyier(we pay taxes people) for about 2 hours.
then take the manual back to auto barn with reciept and say it was for a birthday prestents and somebody already got him a copy.
Get your money back and u have copy of the r33 manual of half the prce.
dont know if it would work but its worth a try.
I bought a copy of the JPNZ manual direct for about $250 delivered to my door from memory. A 20% markup by AB any you get the $299...business I guess!
The manual contains enough information to see you through an an engine rebuild on any RB25/26 series engine. In addition it has all the ECU wiring diagrams and test procedures. However, some issues do exists. Yes there are spelling errors and some ommisions. On the preface, they say they edited it for suitability to Australia/NZ. I would have preffered a direct copy and allowing the buyer the opportunity to decide what is and isn't relevant. It also seems to be a bit haphazard in its organisation. There does not seem to be any reference to later series electrics, such as the integrated coil ignitors, and the inclusion of the throttle switch on some cars in addition to the TPS. And there are errors in some specs which you can correct by comparison to other sections. Unfortunately, there is absolutely NOTHING on anything else to do with the car....NO gearbox/diff/chassis/body info...which left me wanting.
If you have nothing then yes you do need this manual. But dont expect it to do everything for you. While $250 does seem a lot, there are probably 400 pages or so in there, and it would have been quite a bit of work to translate.
    • Hey everyone, just wanted to let you know about an app I use to track the modifications, repairs, servicing etc I do to my R33 GTR. You might like to use it as well. I'm biased because my son just wrote and released it! But I think you might find it useful to... https://trackmymods.com
    • Hey everyone, been on here for a while, but never introduced myself before. 1st import was a R32 GTS Type M, then R33 GTS, now R33 GTR - each one sold to help pay for the next one. Over the years my son has seen me modify and do changes to my imports and was one of the reasons for him to build an app for car enthusiasts like us. (He can only afford a 2007 Honda at the moment, but he'll get there!) Anyway, bit of a proud Dad moment as he's released an app that I use and you all might like to as well. https://trackmymods.com
    • It will sound tragic and you wished you didn't have 1x exhaust per turbo. There's a reason why most S55 owners change to a single mid pipe.
    • Echo the comments about the well preserved condition it's in. It has the aero bumper too for extra points. Nice car, and please keep it like that! 🙂
    • 1. There are no real performance benefits. It sounds different, and as the pipes are not as large diameter you can claw back some undercar clearance or run lower (if that's your thing). 2. Twin pipes, offering exactly the same cross sectional area as a single pipe** will have higher pressure drop - so will not flow as well. That's because there is more surface area of wall per cross sectional pipe area, hence more frictional losses. ** But of course, it is almost impossible to get 2 pipes that are exactly the same XS area as a given typical single pipe. eg, 2x2" is not the same as 1x 3", although it is close. If the 2x pipes add up to less XS area than the single - it will just be flat out worse. If the 2x pipes add up to a bit more than the single, then it might come out as a wash. If the 2x pipes are substantially more XS area than the single, then it will probably flow a little better. 3. No. Why would there be? What have cats got to do with boost creep?*** ***But for f**ks' sake, please run a cat. 4. If you want.
