Ok so ive installed my fmic and just went for a drive and have noticed a few things.
1st question - should the pipe going into the cooler at the bottom right (looking at the front of the car) be hot and the bottom left be cold or the other way around?
2nd question - ive wound my t boost all the way down and im still hitting close to 12 pound by 3.5 k but doesnt pull as hard as when i had the stock cooler in, it just gathers boost slowly instead of bang its there, is this right?
3rd question - Is there anyway i would know if i have it done the install wrong? eg, different sounds
4th question - My car now idles around 1k where as before it would sit about 800rpm, is this cos of the cooler?
5th - Do i need to do the self learn on idle again with the pfc, it is untuned atm?
Thanks
https://www.sau.com.au/forums/topic/232484-intercooler-questions/
If its idling high check for a loose hose clamp or vac leaks.
Might be worth grabbing a can of start ya bastard and spraying it around the fmic and all joins to see if there is a vac leak.
A fmic will soften the power delivery. I also was a tad dissapointed when I first went an fmic. BUT what it does allow you to do is run a little more boost and make more consistent power after you give it a hiding. Prior to the fmic mine felt quite crappy in third gear after I had given it a few full throttle runs.
I know itl be better in the long run with a tune and when i get my new turbo (gota still save a bit more) but i just didnt think it would be so different, it feels like ive lost power and not gained any. Soapy water around the clamps would do a similar thing wouldnt it, if checking for leaks? The blow off sounds sooo much better, bugger putting as aftermarket one on now!
Edited by Damo_c
1. Yes
2. Your running a larger cooler, more boost and no tune. Of course its not gonig to be great
3. Not really
4. Vac leak maybe, as stated.
5. No, but that comes as no surprise with point #2. - YOU SHOULD NOT BE TRYING TO HIT 12PSI UNTUNED.
So what are you trying to say, that i should not be running a hi flow (to4 front vg30 rear) at .9bar with standard injectors, fuel pump, afm and ecu?
I think im at the limit though, breaks down when it hits 1bar so when it spiked to 1.2 it was not happy at all.
it may be wrong but from what i have read an untuned pfc is at about the same level as a standard ecu, is this wrong?
I don't know about that but... standard ECU is not much good once you start modifying the engine. The point of a PFC is that you can change timing, Air/fuel ratios etc - untuned its just a waste of $$$ ( and if you've bought it second hand it could have a tune suited to a set-up which is quite different from what you have and could in fact be worse than your fact ecu).
The maps are basically a direct copy HOWEVER the load points used for a given airflow value is slightly off as the PFC runs a 20x20 vs the std ecu's 16x16 load map.
As a result the pfc usually ends up running a tad more ignition at wot which usually causes the car to det. In my experience anyway. Depends on the level of tune/mods/boost. Would likely be fine for a car running std boost.
Yes it is untuned, i was guna save some money for a turbo then a tune. I drive the car very easy at the moment. I dont wanna waste getting a tune then in 2 months having to get another tune after getting the turbo. I hit 12 psi maybe 5 times since ive had the pfc put in, yeah i am risking a bit of engine damage but when the car is my daily driver and i need to floor it a bit to let a cop go thru or something like that, which happened only a week or so ago, so be it, but ive been very careful as to change at about 2800-3000 light accelaration so bugger all boost. The tune will be happening very soon cos now youve gotten me all worried. Gota use the left over moeny from my wedding to do so. Ive got the t boost wound all the way down but its still boosting up. The pfc is brand new so there is not another cars tune on it.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
