hi i am on a mission to break the 300hp mark with standard turbo
has it been done before?
i hear that some of you have 290hp but haven’t herd for 300hp
please leave any thoughts and or comments
and yes i have searched for hours
https://www.sau.com.au/forums/topic/232494-300hp-stock-turbo-can-it-be-done/
If you have the money to replace the turbo, yes it can be done. The question is how long will it last? One dyno run, a few, a week, a month, a year, who knows?
I have heard of people running 16psi on std turbo, expecting it to blow, as they were ready to upgrade, then it lasted for years and made about 300hp.
It can be done.
Go to the dyno operator, tell him you wanna see 300rwhp.
He can play with some settings and *ta-da* you have 300rwhp.
Can you do it legitimately?
No. 290 is wrong also. Add to the fact you'd NEVER tell the different between 10rwhp anyway.
Stock turbo is good for a legitimate 190-200rwkw 12psi or so (260-270rwhp).
No one has ever run 110mph to backup the 220rwkw/300rwhp on a stock turbo to my knowldge anyway.
EDIT: Obviously with no2 and so on that changes the ball game, so does race fuel.
Hey mate.
I did make 220rwkw and it was still going over a year later. As nismoid has raised, I never did run it at the track but the 220 was very real. IE no tuner influence or funny air temps. It can be done, but just be aware that u are pushing the limit of turbo reliability.
good luck,
glenn
i have a dyno graph but it wont let me upload.........
Edited by 202.3rwkw
Ash 12psi is the "safer" boost limit for a std turbo, but it doesn't mean that some std turbo's aren't able to run higher boost without exploding. It's a game of Russian roulette, as some turbos just come out stronger than others during manufacturing.
At 12psi i have seen these turbos make anywhere between 180-210rwkw. Push the turbo harder and you may make 220rwkw/300rwhp, but it fast runs out of it's efficiency range, hence why 4psi extra may only make an extra 10-15rwkw.
I know of someone who was making 220rwkw with the stock turbo, it ended up spinning apart and bits of metal went through the intercooler and into the engine, now he has to get a rebuild.
Make sure you get the turbo high-flowed. The ceramic parts are just to weak.
How did it get in the engine?? The ceramic wheel is in exhaust side of the turbo. Hence you would find the broken parts in the cat.
I'm not exactly sure how it would work, but when his turbo blew bits of it got sucked though and into the engine.
Guessing(using my head too..!) here, ....
.....but as the turbine disintegrates, this will cause a sudden huge loss of forced air volume on the compressor side toward the inlet, the engine will pull anything in(as avacuum state exists in cylinder/s), .. from ANY side, inlet or exhaust, and given there is valve overlap, and late closing exhuast valves in the equation, this would leave the door to take in 'nasty bits', wide open.
It has got to be something like this i guess. I have yet to have it logically explained, ...so this is my 'stab' at it.
TBH.. just a small amount in the cylinder/s will make things get expensive too.
I suppose logically it should spit it out the 'zorst, but historically this is not the case.
You hear the tales about it, and the result products,.. but yeeeeap, someone correct me if am wrong... enlighten me..!
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
