  • Replies 79
Of course it's rich parents. No 18 year old who has worked full time since they are legally allowed to work could have saved up $70k, unless they are some sort of child prodigy (and my impression of this person is that they aren't especially intelligent).
Needless to say, 70k is almost enough for an R34 GTR, or a 1000hp R32. Being 18, he would surely trash the latter, and probably the former, so let him go for it.
https://www.sau.com.au/forums/topic/23250-1st-car-r34/#findComment-498162
yo im back..... anyway hope you enjoy the car... may i recommend you buy an r33 ('96-'98) GT-R.... then will the remaining money you can get "a sound system and paint that will blow womens clothes off".... and if you dont mind me asking... where DID you get the 70k if your parents didnt give it to you?
https://www.sau.com.au/forums/topic/23250-1st-car-r34/#findComment-498348
Playing the stockmarket?
What about the new Legacy B4 GT? ....aaah, are they in Oz yet? Excuse my ignorance...
https://www.sau.com.au/forums/topic/23250-1st-car-r34/#findComment-498425
Originally posted by Parag0n
IF i had 70K to spend i would most likely end up getting a Mazda RX-7 FD3S, they go hard when modified properly.
they go hard... and they die hard..
what goes up must come down...
very unreliable engines... but otherwise.. great car
https://www.sau.com.au/forums/topic/23250-1st-car-r34/#findComment-498715
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
