(posted this also in the Naturally aspirated section, thought id post here since its a VIC thing)
just looking for some clarification.
looking at getting new rims (need em bad) and looking around. most 17s/18s are 7-8" wide. thing is, my current stockies, as stated by the placard are 6" wide, and im in Vic, and the restriction is stated as being "more than 25mm greater than the widest wheel specified by the vehicle manufacturer for that model or vehicle series" to be compliant.
now, thing is, take a R33 GTR for example, they came with 17x8? inch wheels, correct me if im wrong someone. now they came from the same series, so would that mean that legally the max diamatre would be 9"? for any car of that series, including mine.
just looking for some answers, and if anyone out there has actaully fitted wide rims to their non-turbos, let me know. it should save me a bit of trouble in the long term.
cheers
https://www.sau.com.au/forums/topic/232514-wheel-widths/
inside your door jam there should be a tyre placard, it will have the rim size on there and when checked they will go off that size, dont bother pulling it off either as it is a roadworthy item and you can get defected for not having one.
https://www.sau.com.au/forums/topic/232514-wheel-widths/#findComment-4079836
well i have a gtr tyre placard thingy on my gtst so i guess my restrictions based on taht. id be well surprised to see an officer pull the measuring tape out for tyre widths.
Get your self a GTR placard if your worried about the size.
These are available brand new from Nissan. Give Ferntree Gully Nissan a call, they will be able to help.
But honestly I really don't worry about this on my car, I have 18x9.5 all round with +20 offset on my gts-t. So many cars have big wheels these days, I think the cops tend to look past this and worry about mods to the engine/ suspension more. When ever they pull me up they go strait for my bonnet not my wheels.
https://www.sau.com.au/forums/topic/232514-wheel-widths/#findComment-4079938
there could also be insurance issues, even if the police don't pull you up on it, an insurance company might if you ever make a claim.
i was looking around at my car (r33 gtst) for the same thing, the one inside the door jam only had some tyre sizes and wasn't really helpful. The sticker with the wheel widths was stuck in my glovebox, and it had the gtr size on there (17x9). look in there and check, i'd be confident going 1 inch wider than the widest on the sticker.
https://www.sau.com.au/forums/topic/232514-wheel-widths/#findComment-4079946
they dont neccesraily have to measure the tyres to tell, they could just read what size is printed on the tyre and compare it to the placard.. maximum width stated to be 215, so theoretically 225 is my max. then again the idea of replacing the placard with one off a GTSt/GTR is a good one.
anyone here fitted 18x7.5 rims to their line? howd they fit and what offset were they...ones im quoted are 18x7.5 with +38 offset.
cheers
https://www.sau.com.au/forums/topic/232514-wheel-widths/#findComment-4080993
cheers
Hey mate.
Anything less than 8in wide looks way to skinny. 33's will easily fit 8in front and 9in rears with an offset in the 30's.
Have a read of this thread and see what some people are running. Nobody likes skinny skylines. Fat is better! :(
http://www.skylinesaustralia.com/forums/in...0&start=360
BTW. GTR rims are 9in wide so you should be safe with 9's however I have heard that staggers rims are not legal. ie. 8in front 9in rear.
I've always run staggered rims on my car and never even given it 2 thoughts.
https://www.sau.com.au/forums/topic/232514-wheel-widths/#findComment-4081019
I tried my 17 x 9.5's (+18 I think) on the rear of my 33 and she was a no go, how did you get those under there????
https://www.sau.com.au/forums/topic/232514-wheel-widths/#findComment-4081039
thats true but usually if theyre going to that much trouble your gonna get done for something technical even if its something really minor like babyseat anchors and turbotimers, etc. I guess your just minimising your risks. In my experience of getting pulled over, they never once checked the widths only tread..touch wood..ha
https://www.sau.com.au/forums/topic/232514-wheel-widths/#findComment-4081598
cheers
i have 18x8.5 and they fit fine, just have to make sure you get the right offset, no idea what my offset is as i bought them new and did not have to worry about that stuff.
https://www.sau.com.au/forums/topic/232514-wheel-widths/#findComment-4081934
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
    • To re-cap, I bought: https://www.alibaba.com/product-detail/Lsailt-8G-Infiniti-Q50-Q60-2014_1601171829627.html?spm=a2756.trade-list-buyer.0.0.2cd476e9FTIlKE As you can see, if I bought 20 it was $653, but I bought 1 so it was $1,170. I was very tempted to buy 2 and resell 1 at 25% cheaper. @MBS206, I am not sure if they do a Kluger one, here is their list but it might be there under a global model name: http://www.lsailt.com/product/android-interface?page=1 Keep in mind these full android replacements have basically all the bits a phone does (cpu, ram, storage, wifi, bluetooth, usb interfaces) other than a screen (it uses a host), thus the $800+ cost. Android Auto screen mirroring is MUCH cheaper as it's just a cut down shell, input mirroring and output mirroring BTW I also need that "screen off" feature, it is much harder to see wildlife even if a dash is reasonably dark. Both the Fuga and V37 have display off buttons for night use, they just come back on for a second or 3 if you interact with it, eg skip a song.
    • I use FCC car launcher. It has an option for different backgrounds, so instead of turning the screen off you can swipe 'up' to a black screen with no background/icons. (mine has the time on it only). It's kinda nice. Also lets you use gestures to say swipe to go to next song, etc.
