  • Replies 42
FINAL LAST PRICE DROP $250
FC HAND CONTROLLER CODE 414-AN029
If that controller fits mine, I'll take it off your hands for the $250.
My PFC is for R32 GTR, and is PFC 9711-0022, apparently the model is 414-N011. I couldn't work out from the FAQ whether it'll work...
Edited by NRB
Thanks abu, I've e-mailed nengun to find out if it's appropriate. If so, you've got yourself a buyer Dush.
All good mate. Your more than welcome to come down and test/inspect it if you need too...
just give me a call on the number provided on the original post =]
  • 4 weeks later...
how is this not sold is beyond me! great price especially when you see so many ppl enquire on power fcs for sale, "would you sell the HC seprately??"!! good luck dush
I'm amazed it's not sold too - I'm trying to find one! It's turning out to be a little harder than I originally thought.
Yea i know... I want this gone... ASAP
Edited by Dush
I gUess the "N" in your code stands for Nissan, after doing research i think Supra is 415-T001 ("T" maybe for Toyota?)
Your probably right. Dont know too much on information on the hand controllers..
give ya 120, provided it works (ill come test to see if it works)
nah sorry champ too low...
You can still come sus it out if it works tho =]
    • Anyone want to make me an offer to take my v36/g37 3.7l manual coupe in full? Off memory it was low 100k km but the battery is flat so can't tell right now. What's wrong. I had engine problem's that led to a nice clunk. It made it home but it wasn't pretty for the last few kms. Happened under revs. Sounds like bottom end.. never got around to fully checking or fixing it so the car has sat still and unregistered for a few years. Minor bump in front end set the pedestrian protection under bonnet airbag off and that was meant to be repaired, but while waiting for the repair (parts to come) I got the engine problem. The rest of the car is in decent condition. All drive line is good. All interior is good. Leather interior. Wheels in good condition and decent tyres although the ps4s are likely a little too old now it's sat still. Colour of the car is pewter off memory, the dark grey colour. In Camden NSW. Would need a tray back pickup.
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
