Item:
1 x Defi 60mm Boost Gauge (2bar reading) - Stepping Motor Drive
1 x Defi Boost Sensor
1 x Defi Daisy Chain Loom (for other Defi Gauges
1 x Defi Instruction Manual
2 x Foam Strips
(all you need to buy is a 60mm cup, a holder, and the Control Unit)
170820088321200aj5.th.jpg 170820088291200av7.th.jpg 170820088311200nl5.th.jpg
Unknown, but it is 2nd hand (un-used on my part) - as far as I'm aware, these are not available anymore!
Condition:
As new condition... wires are still all wrapped up from the box.
Price:
$150 + delivery / pickup
To Fit: (What car)
Any car really, but you will have to purchase the Defi Control Unit (around $80?)
Sydney Northern Beaches
Contact:
PM Preferred
Comments:
Reason for sale, only ended up using Oil Temp n Oil Pressure
This is the real deal, not some fake imitation crap... Defi are amongst the best in the market so make sure you don't miss out on this opportunity to snap up a nice unit at a low price.
FYI this gauge is not like the usual Defi items you see on Nengun with the black face, this gauge is visible from square one. It reads in kgf/cm2 and has a "warning light" and "peak" indicator. As with all Defi gauges, replay is available through the control unit.
  • 3 weeks later...
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
    • I was chatting with an ex SAU person who is involved in chooning euros now. He was saying the factory cars like Audi VW etc have something like 2000 tables that the ECU uses for getting everything "just right". Compare that back to any aftermarket ECU, and you'd be hard pressed to surpass 50 lookup tables. Even the Ford Barra engine has a few hundred lookup tables to run it (and they're still working some tables out too!)
    • Grab a temp probe, and probe each exhaust inlet runner with it sitting idling. Each one should be pretty darn close to the same temp. If you've got some reading higher or lower than the others, it's likely either air flow isn't equal, or your injectors aren't equal to each other.   The other things to check, is from the wiring changes that were made, were any earth's or grounds moved/changed.   Lastly, for the strut brace issue. It's not perfect, but can you get away with slipping a washer or two under the strut brace to raise it, and it still clean the bonnet? If you can, work out the height you need, that the motor can't torque up into, and get a spacer made for each side.
