Yo blokes,
Recently i read a thread by forum member URAS which highlighted the benefits of a blitz ebc with gain control over say a manual boost controller. IT basically showed better gain throughout the low/mid revs which was quite surprising.
Im in the market for a new EBC as mine currently is a HKS EVC version 3 and i would like an update. Now i was gonna buy the blitz ebc recommended but since ive come across the new HKS EVC version 6 which utilized a stepper motor instead of solenoids.
Now is this a new thing or do other manufacturers use these? are they better at controlling wastegates?
this is the link from ebay, it seems like a good price for a tough looking module
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...em=360079097260
what you guys think! oh and its for my R34 GTR; so standard twin turbos with internal gates
-Johnny
https://www.sau.com.au/forums/topic/232551-hks-evc-version-6/
-Johnny
HKS have been utilizing the stepper motor for years over the cheaper solenoid version offered by other manufacturers. It is the best form of boost control on the market, that's why HKS use this method. I say go for it as you won't look back. You can even buy software for it to tune via laptop to make you boost control better again. CheersMarty
Solenoids don't give creep if set-up correctly, its as simple as that. No EBC does really.
Some are just harder to set-up than others depending how familiar you are with them etc etc
I've never seen any evidence to say one style is better than the other, i'd be inclined to say they are both equal in their own rights.
Thanks for the comments so far. I agree that many high powered turbo cars still use solenoids without a hitch so im still debating but it looks like im steering towards the HKS unit as it has a brilliant black and tough incabin unit.
at 600bux its not cheap but then again, im not either.
I will definitely post up results of the response when i run it on the dyno. My last dyno run net 235awkw and now i will be adding this EBC and apexi pods which are already installed to see if i can mimmic the nice midrange gains that URAS tested.
BTW who is that bloke Trent? is he a tuner? cos he sound like the go-to guy.
let you know in an hour or so :dry: i have a killer S15 here that i just finished installng a HKS EVC 6 (had it on dyno with various other controller before this on) into.... going on dyno now.
will keep you posted.
in my experience the stepper is as good as any other single sonelnoid controller out there it is just the dual solenoids which are slightly superior.
let you know in an hour or so :P i have a killer S15 here that i just finished installng a HKS EVC 6 (had it on dyno with various other controller before this on) into.... going on dyno now.
Great thanks mate, appreciate that and the information in your previous thread. Put it this way, i was 2seconds away from buying the power fc EBC kit! and what i waste that would have been.
Gotta love the look of the hks module huh
Just got one put in my car yesterday at IS Motor Racing. With the extra boost I picked up 20-30 KW from coming on boost all the way through the rev range to peak power at 6700RPM. My latest dyno graph is in the RB26 dyno results thread page 8
Thanks man, ill check out your dyno graph now. Seems like im gonna be real happy with this bit of kit.
Ok now i must admit the first few moments with this kit gave me the shits as the instructions were more confusing than helpful :blink: it turns out some-one had played with it while i was washing up.... a simple full system reset and all was good.
After the firsat few hiccups the unit is actually VERY easy to use, it holds boost extremely well and is nice and clear to view peak boost ect. Wiring was imple and THR, RPM and SPD was the only other input needed to make it fully functional. It allows for BOOST vs RPM, THR or SPD
the only down side is it could not match the GIZZMO unit (about 200rpm slower) for ramp rate even after countless differrent settings. i have attached a boost comparison. i would rate this unit as an 8/10. The GIZZMO unit (red line) had a slight problem holding boost up top on this run but subsequent runs had it fixed easily but i forgot to save the run :P for a $399 (full retail) boost controller it actually outgunned the HKS :banana:
On the attached Dyno sheet (ingore bottom specs) The thin red line is the GIZZMO unit and the orange is the HKS.
I really wanted to do a back to back with the IDIII (blitz) as it is my favourite due to past results but i was out of stock :( but based on these tests i reckon it would also ramp quicker than the EVC6 as ive upgraded a few GIZZMO controllers up to IDIII's (against my advise) and had zero improvements.
Hi Johnny & All
Sorry to hijack your thread. I also bought the EVC6 and even post up a thread bcos im not sure how to utilise the Boost Correction setup for partial throttle. Appreciate some help from those who has installed this unit.
http://www.skylinesaustralia.com/forums/Ev...ap-t231124.html
Can help on what's the best settings for FUN 5 (THR & RPM) for T04E turbo im using which is laggy up to 4500rpm.
Thanks Trent for da update, i hope you worked out all the settings. Where do you get all your cars tuned? do u have a shop as i want a better tune on my power fc and someone to professionally install and tune da ebc.
I have been holding out on calling anyone because i want to find someone who will treat the car like it was their own.
btw driftmeister, i hope you work out all the issues in your car.
Yeah the setting were no dramas, just some-one with itchy fingers had a play whilst i was away cleaning my hands :) . i have my own shop and dyno facility. I have included some pics of the install. We fitted it into the ashtray (do lots of custom work) so it was hidden, after the install the lid sat over it and it all looked std. There are plenty of decent shops around what area are you?
Hey blokes,
I just thought id update this thread with some pics of the EVC 6 if anyone is interested in purchasing one in the near future.
I would like to comment on the quality as it seems very nice, solid and quite heavy. The screen is also very tasteful from an asthetics point of view
I will be having it installed at creatd ms on wednesday next week so i should be able to post a little review on its strengths and weaknesses.....compared and contrasted to the current EVC version 3.
That's nice install though it's hard to look at unless car is stationary. Had mine installed at the astray area below the player on 34GTT so it's slightly upright. Will load up pics soon.
yeah customer wanted it there, once it set though there is very little need to ever touch it.... the way i see how much boost is controlled by your right foot only the maximum is controlled by the boost controller :D
johnny, I will be shocked if the EVC 6 properly tuned is any better than an EVC 3 properly tuned. they both seem to use the same hardware to me. maybe the software has improved enough to make some improvement but I'm a little dubious.
Hey baron, Im sure that your right but again i just like the look of the unit so im upgrading. I have a booking for next wednesday at creatd ms for intallation so hopefully i will be able to give you some results.
also anyone who is interested on the gains of pod filters on their gtr as well
oh and i will be selling the HKS EVC 3 for a really good price for anyone who needs a boost controller and is a little low on funds.
Johnny
    • I have engineer in my job title One of or motto's though is "we make and we break"
    • This is actually 2 whole different trains of thought that need to be addressed separately. No, as Matt says above, "Engineer" is not a directly protected title. A lot of guys who just do mechanical design via CAD, with or without even some sort of associate diploma in engineering, often have the job title of "Design Engineer". A train driver can probably still describe themselves as an engineer. But, to usefully get employment with anyone as a proper engineer, you're going to have to have at least the necessary and relevant degree qualification. You're not going to get a job as an electrical engineer if you have a chem eng degree, unless you can demonstrate x number of years of working in that capacity, sufficient knowledge, etc. Having the degree is at least in indication that you've seen the relevant text books, even if you haven't read them (like pretty much the last 10 years of graduates!). To be a self employed engineer.....you could get away with quite a lot pretending that you're suitably qualified, without actually being a proper engineer. But, you will find yourself unable to work for a large section of the client space because a lot demand CVs and capability statements when considering contracting for any engineering work these days. Insurances too. If you're not a proper engineer, it will be much harder to obtain proper PI insurance. Insurance companies have gotten hip to that. The "Professional Engineer" thing is a thing in Australia. If you have the right qualifications and experience you can apply to the relevant engineering top level body (mostly Engineers Australia, the less said about whom, the better), to be assessed and approved as a Chartered Professional Engineer, CPE. There are high bars to get over and a requirement for CPD to maintain it. The RPEQ thing is similar-ish, in that you have to demonstrate and maintain, but the bars are a little lower. It is required to be RPEQ in order to sign off as an engineer on any engineering design in Queensland. The other states haven't fully followed suit yet. There's "engineering" and there's "engineering". Being an engineer that signs off on timber (or even steel) frames for housing projects, council creek crossing bridges, etc, is a flavour of civil engineering that barely warrants the name, description and degree. That would be soul crushing work anyway. Being an automotive engineer working in the space where you have to sign off on modifications to cars and trucks would also be similarly soul crushing. At least partly because of the level of clientelle, their expecations, depths of bank balance, etc. And that brings us to your second question. No, we do not have professional engineers "do vehicle inspections". Well, not the regular roadworthies, etc etc. That's done by mechanics. There might be some vehicle standards engineers at the various state govco inspection stations where cars go to get defects cleared and so on, but that's because they (the cars) are there specifically for defect inspection and clearance and so the stakes are a little higher than on an annual lights and brakes working check. But, if you modify a vehicle in Australia, you have to get it engineered. A suitably qualified (and effectively licensed, which I will get back to) automotive engineer will have to go over the application, advise on what would be required to make the mods legal, supervise some parts of the work, inspect and test the results, and sign off. The "licensed" aspect comes from there being a list of approved engineers to do these things in each state. They have to jump through hoops set up by the govco vehicle standards divisions that mean only the suitably qualified can offer to and approve such mods.
    • It's got a problem Prank... It looks like both washer spray caps have fallen off this car... 😛
    • Meh, it's only got to last another 10 years or so until you'll be forbidden to drive it. Keep it dry and forget about it.
    • The title of Engineer is not protected. However different states have different rules about what an Engineer requires to operate. Engineering for a motor vehicle modification is very different to engineering for a bridge, electronics, etc, including what that engineer needs as certifications.   In Canberra, "Engineer" is the loosest category with basically nothing stopping you calling yourself and engineer and designing a bridge or building. From what I've reviewed, QLD has the strictest requirements through RPEIQ.
