Lexus GS300
poped the bonnet of this car, and found (jus like the fast n furiuos) 2JZ-GE, minus the turbos of coz.
but yea, dunno nothing about toyota, but is this the supra or soara engine?
Does anyone kno the specs of the lexus 2JZ-GE? it has VVTi
and doesn't go that bad for such a heavy car.
Is it just the same as a non turbo supra, juss stamped lexus with VVTi...?
It redlines at 6000rpm i think. is that the same with supra?
Originally posted by T0nyGTSt
IMO the Aristo bodied GS400 with a TT 2JZ-GE or a 1UZ-FE v8 and a Getrag 6 speed would get me out of Skylines completely.
Ditto... Sort of... Maybe not all the way out... :D
I want both!
RE the GS300: Don't know the specs but this was Lexus Australia's "performance" car when it was released...
Originally posted by <<>>
k,
wot bout the lexus GS300 engine?
anyone kno the exact specs?
I can give you exact specs of the JDM... just knock off 50kw for the Aussie model :D
Engine: 2JZ-GE inline 6cyl DOHC 24 valve
Capacity: 2997cc
Power: 230ps (171kw) @ 6000rpm
Torque: 31.0kg/m @ 4000rpm
The lexus GS300 is a very nice car... a very nice transmission on those cars. You will also find the IS300 and a 2jz in it to. A supra engine in an IS300 would turn me of skylines forever :stupid:
the Gs300's are 166kw@ 6000rpm and 298nm @ 4000rpm and about 1680kg. IS300 are 157kW @ 5800rpm and 288Nm @ 3800rpm but are about 150kg lighter
 Share
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
    • You need the kit turbo taipan has shown you because that manifold ia designed have side feed injectors
    • @johnnysr22 did you end up installing the little screen thingy and did it work ?>
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
