I have a gtst r33 S2 and wanting to get a atmo BOV but dont know which one to go for since have heard about stalling issues. Car is pretty much stock engine and stock ecu besides exhust system. Which would be the best bov to get that wont cause stalling?
thanks
https://www.sau.com.au/forums/topic/232561-which-bov-to-get-for-r33/
all atmospheric one will cause you to have stalling issues,
But if you wish to get a atmospheric venting one i would recomend the turbosmart Dual-port one. this is because you cau set the BOV to vent to atmosphere, be plumbed back, or it can do both at the same time.
stock is good, same as gtr bov
if you want aftermarket I could suggest a GFB Stealth-FX atmo/plumb-back (100% adjustable) bov, nice sound, no stalling issues on plumb back mode
full atmo isnt a good idea IMHO, at the least some sort of adjustable one to get the 'mixture" of atmo/plumb back correct
+1 For stock bov, or GTR one.
I have a GFB Stealth FX and atmo sounds great. Plumb back is also good, nice and fluttery. If you put it half way you can have a quieter atmo sound.
I had it on atmo for a while and never had an issue with stalling, it did feel weaker though like the intake feel was different.
Just keep the stock on, or get a GTR one, and replace the stock airbox with a pod.
An atmo is just going to give you the shits after a while anyway.
I cant see the point in spending money on a aftermarket BOV?? its a bit of money to drop for just a sound...
Spend the money on a frontmount intercooler!
Edited by Az_StrYdeR
ok, ive heard that some say if you adjust the BOV correctly that it will eliminate the stalling issue, is that true or is the dual port the only way? Quote
no matter what you do to adjust the BOV you will still have to stalling problem. i would recomend a dualport one, because if you do get sick of the sound that it makes you can very simply pull the trumpet off the BOV and cover the port with the backing plate.
Keep the stock BOV and replace your air box with an Air Pod.
A pod will give you the 'Choo' noise and only when the turbo is Spooling.
If you get an aftermarket BOV it will "AARRCCHOOO" even when you are not boosting = Wank Factor
Or save the cash and go for a front mount intercooler. You will be benefiting the car a lot better.
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
