Hey guys I got this assignment for tafe and I need a few responses from people within my target market soo the easiest way i could do this is through an online survey to a few car clubs
If you guys could please fill one out for me that would be great. It’s for a business plan for an auto accessories shop in one of my classes.
The survey is spread out over 2 links there’s only 15 or so questions altogether J
SURVEY NUMBER 1
http://www.surveymonkey.com/s.aspx?sm=CrnRZEtuwI_2f1kmc9oDBOAA_3d_3d
SURVEY CONTINUED
http://www.surveymonkey.com/s.aspx?sm=gY2p_2fWRgcOFuMbLk2VtchQ_3d_3d
CHEERS heaps guys
If i have posted in wrong section could u please redirect cheers
https://www.sau.com.au/forums/topic/232563-automotive-survey/
